Kubota 3400
/ Kubota 3400 #1
mikel7758
gravely c8, gravely 5260,gravely comm10, gravely l
Hi All. I have a Kubota 3400. There is a spring loaded lever on the right side front of the engine that looks like it should have a cable or something on it. There is a hole in the end but nothing is attached. It is on top of what I believe is the hydraulic pump. Can someone tell me it's purpose?
Thanks
/ Kubota 3400 #2
I'am out back in middle of work back here.I'am sending you pics of my L3400DT.
At least for now you can see my motor till we/us or TBN-er can fiqure it out.
Boone
/ Kubota 3400 #3
What you are looking at is on top of the injector pump, NOT the hydraulic pump, which is at the rear of the engine on the same side.
That lever you refer to is a manual fuel cut-off. If in the event that the electronic switch that cuts off the fuel fails, you can use that lever to be able to shut the tractor off.
Kinda suprising, but I do not believe that is mentioned in the manual either:confused2:
/ Kubota 3400 #4
Who says you can't learn something new every day??
Thanks for the insight, I had no idea that lever was even there. And you're right on something else too, the manual makes NO mention of it either.
Sean
/ Kubota 3400 #5
Me three! thanks
James K0UA
/ Kubota 3400 #6
News to me too... I'll check mine out also..
/ Kubota 3400 #7
If this is what you are talking about, It's the engine stop lever like LD1 said.
/ Kubota 3400 #8
How's this?? Better???
/ Kubota 3400
Mystery solved! Thanks to all!
Mike L
/ Kubota 3400 #10
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
Deere 333E (A60462)
Deere 333E (A60462)
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2013 Bobcat T190 (A64126)
2013 Bobcat T190...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
