Mini-Backhoe
/ Mini-Backhoe #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Have you ever seen one of these?
I built this just to see if it would work, and it did quite well.
I used a fork tine as the base and welded the pin mounts on the tine. The pictures show a 16 in bucket, and there is a picture of the hole I dug.
Fairly inexpensive, using a spare fork tine, a cyl, bucket, pins and brackets.
And yes, I know the cyl barrel is touching the fork base.
With my Power-Trac, I can turn the front end to dump.
/ Mini-Backhoe #2
That's pretty slick. It raises a few questions for me about the stock PT mini hoe for the 425.
1. Could it make sense to have a wider bucket fabricated that could bolt on in place of the 9" bucket when desired?
2.Would it be possible to dig deeper by adding a 2-3ft fabricated extension between the QA and the mini hoe?
(I guess one end would need a manually activated QA.)
3. Would it be possible to fabricate a QA adapter that mounted the mini hoe at a 90コ angle so it could grab a tree trunk or pole using a thumb?
These questions may be way off due to my inexperience with the PT. But just wondering...
/ Mini-Backhoe
The bucket width will depend on the soil condition, If it is sandy like I have, it could go really wide like a ditch bucket. Someone has all ready done something similar. I also have a 6 in bucket for drainage ditches.
Here is something to grab trees and and cut off trees.
/ Mini-Backhoe #4
The bucket width will depend on the soil condition, If it is sandy like I have, I could go really wide like a ditch bucket. Someone has all ready done something similar. I also have a 6 in bucket for drainage ditches.
I have tried the 12 inch bucket and it works very well on clay and wet stuff. This is most of what I have. PT makes one, I just cannot justify it yet.
/ Mini-Backhoe #5
Have you thought about adding some braces to keep the fork from bending? It looks like you have room.
Ken
/ Mini-Backhoe #6
Thanks for sharing J J, I have seen those for skid steers{or atleast they were very close}. I think they would be handy for some simple jobs, but I would not want to dig a pond out with it:laughing:
/ Mini-Backhoe #7
They're certainly not a backhoe. I've used mine (made by PT) to dig a footer for the foundation of a family room addition. At least initially, it is much faster to use it, and back the tractor up, ripping a trench rather than digging it one little bucketfull at a time. Once you get a couple feet deep then you have to start scooping it out with the bucket.
I too would like to try a 12" bucket (I have only the 9"). The PT certainly has enough hydraulic force to handle one -- but I wonder if it is heavy enough to push a 12" bucket into the ground -- if I hit a rock or root with the 9" one, it will quickly lift the front of the PT up off the ground.
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2016 Ditch Witch SK752 (A64047)
2016 Ditch Witch...
SHOP FANS AND MIRRORS (A63569)
SHOP FANS AND...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2022 EZ-GO ELITE...
