Vane pump for splitter
/ Vane pump for splitter #1
rusty32
Hi , been a lurker for some time now. We heat are shops at work with wood, I work at a recycling/garbage center. During the winters we store most wood inside to keep it dry. I would like to build an electric log splitter for use indoors, mostly constructed out of stuff leftover from are garbage trucks and things from our scrapyard. We recieved a brand new bosch/rexroth vane pump in scrap 30gpm @1750 rpm and 2000psi. From what i found it would take 40hp to run this pump right which we get thoose in the scrap yard too. But would a vane pump work well in this situation. Thanks
/ Vane pump for splitter #2
Yes a vane pump will work. Do you need the 30 GPM flow rate? If not and you can get a 1200 RPM motor this would lower the flow rate to around 20 GPM and your HP 25 - 30.
Just keep the oil clean since vane pumps are little more sensitive to dirt than gear pumps.
Roy
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2025 Tree Boom Mini Skid Steer Attachment (A61572)
2025 Tree Boom...
(2) UNUSED 10-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 10-16.5...
Caterpillar 350/350L Excavator Service and Parts Manuals (A63117)
Caterpillar...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
