Kioti CK 25 Preheater problem
/ Kioti CK 25 Preheater problem #1
kzwooly
kioti ck25
I am new to this site, but sure glad I found it. I followed members advice on cleaning dirt and dust from the relays. Now it starts perfectly. Thanks guys.
I do have another question. Moving in and out of 4 wheel drive is quite the effort, especially from 2 wheel to 4 wheel. I have lubed all visible pivot points. Does anyone else have this problem?
/ Kioti CK 25 Preheater problem #2
Here's a little trick...
Go slowly in reverse, step in the clutch before coming to a stop. Once the tractor stops rolling, try shifting the 4-wheel drive lever.
The joint that needs to be kept lubricated is where the shifter shaft goes thorough the transmission case. You need to spray penetrating lubricant right at where the shaft goes through the case, work the shifter, and repeat a couple times. That is where they get a little sticky.
Hope this helps,
/ Kioti CK 25 Preheater problem #3
........ Moving in and out of 4 wheel drive is quite the effort, especially from 2 wheel to 4 wheel. I have lubed all visible pivot points. Does anyone else have this problem?
Have you tried moving the tractor to relieve torque build-up in order to shift in or out?
Hope this helps,
Thanks, I will follow your advice. You guys rock. By the way, my nearest dealer is 280 miles away. I would love to do business with you. Miles don't matter.
Yes, and it works going from 4 wheel to 2 wheel but not opposite. Txs
/ Kioti CK 25 Preheater problem #6
The worst area is as MIE mentioned. Where the shaft goes through the case. Mine, at first, was hard to shift also. I used some penetrating oil first and moved it back and forth many times to loosen it up. Then I used spray white lithium grease. Used the lithium about once a week for several weeks. It now moves easy except when there is pressure on the gears as mentioned. Gentle, barely moving forward or back works for me. If you have a fel, lift the front tires off the ground and try to shift. It should shift easily. If it does, that's just the pressure on the gears making it stiff. If it doesn't, keep lubing.
KMC 4R PEANUT INVERTOR (A64276)
KMC 4R PEANUT...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Ford F800 (A63689)
Ford F800 (A63689)
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2015 Dodge Journey SXT AWD SUV (A61574)
2015 Dodge Journey...
