Planters Size of JD 71 2-row planters?
   / Size of JD 71 2-row planters? #1
Amos1
West-Central Illinois
Ford 861 Powermaster
Hello all, new member, first-time posting! (Thanks Doc for helping me get registered!)
I'm thinking about getting a JD 71 2-row planter, and I'm wondering what the deminsions and weight are for transportation purposes... (I have a 5x8 heavy-duty trailer. Will one fit in that?)
Thanks in advance for any help!
   / Size of JD 71 2-row planters? #2
Yes. It will easily fit in the back of a pick up truck. I did it.
Do you have a rough idea how much they weigh?
Thanks Leadpoison!
   / Size of JD 71 2-row planters? #4
Two people can move it around pretty easy. If you are using a trailer you can just pick up the front and wheel it up the ramps. Three to get it in a truck because of the height. You will want to set the front discs on a piece of wood rather than metal.
My trailer has a Tilt Bed... Plus, there's an old boat winch welded on the front that I can use also... I was mainly concerned if it would Fit in the trailer, but was curious about the weight, too - hard to tell how heavy they are from a picture....
Thanks again for the help! :thumbsup:
   / Size of JD 71 2-row planters? #6
Thanks Leadpoison!
Each planter unit weighs 80lbs without hopper and front packer wheel (if included). Your 2-row 71 is most likely under 250lbs. Bring along a ratchet set and if needed you will be able to remove the units from the toolbar in a few minutes.
Hey, thanks for that info and tip, Luremaker!
I'm guessing from your handle, you uh... make lures? :) Would you have any use for some feathers from a Barred Plymoth Rock Rooster? (I have one who is close to meeting his demise...) I know some guys use the feathers to make flys...
   / Size of JD 71 2-row planters? #8
I just had one delivered 2 weeks ago. Bill of lading said 385 lb. It's about 3.5 feet wide and 3 ft tall and about 4 feet front to back. It should fit on your trailer no problem.
Thanks for the info, Flusher! Appreciate it !!
   / Size of JD 71 2-row planters? #10
You're welcome. My JD71 was shipped from Minnesota
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
