Planters Size of JD 71 2-row planters?
   / Size of JD 71 2-row planters? #1
Amos1
West-Central Illinois
Ford 861 Powermaster
Hello all, new member, first-time posting! (Thanks Doc for helping me get registered!)
I'm thinking about getting a JD 71 2-row planter, and I'm wondering what the deminsions and weight are for transportation purposes... (I have a 5x8 heavy-duty trailer. Will one fit in that?)
Thanks in advance for any help!
   / Size of JD 71 2-row planters? #2
Yes. It will easily fit in the back of a pick up truck. I did it.
Do you have a rough idea how much they weigh?
Thanks Leadpoison!
   / Size of JD 71 2-row planters? #4
Two people can move it around pretty easy. If you are using a trailer you can just pick up the front and wheel it up the ramps. Three to get it in a truck because of the height. You will want to set the front discs on a piece of wood rather than metal.
My trailer has a Tilt Bed... Plus, there's an old boat winch welded on the front that I can use also... I was mainly concerned if it would Fit in the trailer, but was curious about the weight, too - hard to tell how heavy they are from a picture....
Thanks again for the help! :thumbsup:
   / Size of JD 71 2-row planters? #6
Thanks Leadpoison!
Each planter unit weighs 80lbs without hopper and front packer wheel (if included). Your 2-row 71 is most likely under 250lbs. Bring along a ratchet set and if needed you will be able to remove the units from the toolbar in a few minutes.
Hey, thanks for that info and tip, Luremaker!
I'm guessing from your handle, you uh... make lures? :) Would you have any use for some feathers from a Barred Plymoth Rock Rooster? (I have one who is close to meeting his demise...) I know some guys use the feathers to make flys...
   / Size of JD 71 2-row planters? #8
I just had one delivered 2 weeks ago. Bill of lading said 385 lb. It's about 3.5 feet wide and 3 ft tall and about 4 feet front to back. It should fit on your trailer no problem.
Thanks for the info, Flusher! Appreciate it !!
   / Size of JD 71 2-row planters? #10
You're welcome. My JD71 was shipped from Minnesota
SKID W/ CONTROL BOX & CEN PUMP (A55745)
SKID W/ CONTROL...
MINI EXCAVATOR BUCKET 32 (A55745)
MINI EXCAVATOR...
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A55851)
1994 Generac...
2012 PETERBILT 367 (A55745)
2012 PETERBILT 367...
Rooster Weathervane (A55853)
Rooster...
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
