Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,911
- Tractor
- Kubota BX25
Danner, and all,
What is the secret to using ether one to get a level result when they tip one way or the other when a tractor wheel hits a bump or rut? I get better results with several passes with the FEL backblading with the bucket bottom.
I want to get a 60" backblade that tilts up on one side to use for making ditches I can still mow. Then I have thought, doing flat work, about adding a guaging wheel each side and using a flex connection on the top arm That way the blade will not follow the tractor wheels. I am good at fabbing my own stuff. My box blade is only 48" so not sure it is wide enough to be effective with the wheels.
Any body done any of this or can share some operating secrets.
Ron
Ron
