To split, or not to split: that is the question.
/ To split, or not to split: that is the question. #1
DAY
Eastern PA
Ford 4500 TLB, Kubota L2900GST
With apologies to Wm Shakespeare!
If time is not a factor, and there is a place to get the wood off the ground, and under cover, is there a reason to split the log?
(Assuming it will fit in the stove:laughing:)
/ To split, or not to split: that is the question. #2
Splitting provides more surface area for drying, although most drying is via the cut ends. It also tends to be more stable in a stack.
Mike
/ To split, or not to split: that is the question. #3
Good Afternoon Steve,
Assuming that your using a conventional wood stove, not an outside furnace, than I would agree with Mike...
Split it and cover the top of the pile.
If your not going to be using the wood for a couple of years, then just get it off the ground, cover the top and split it when time warrants it... JMO !;)
/ To split, or not to split: that is the question. #4
It would depend some if you want a hot fire or a slow smoldering fire. Another thing to consider is the wood species with different drying times. I personally would be doing a moisture test in the center before putting it in the stove. One test on the largest piece would give you a good indication. Other than the things mentioned just burn it. My father usually put a big round of oak in at bed time so there would be coals to start from in the A.M.
/ To split, or not to split: that is the question. #5
To me, it depends on the size of the wood and how long I have to dry it. For the past two years I have been building holz hausens. From the following pics, you can see I use a mixture of split and not split. After a year, it is dry all the way through. The only thing I found is that stacking wood on end on the ground inside keeps the bottom inside row from drying, so I started laying all wood vertically and it works just fine. :thumbsup:
The circle diameter is 10'.
The center post is 12' buried 2' in the ground.
I stack it about 9' as that's as high as I can toss it.
Its about 5.5 cords of wood in that one pile. Nice and compact.
/ To split, or not to split: that is the question. #6
Hey Moss, where do you stick the forks to pick that up ??:laughing:
/ To split, or not to split: that is the question. #7
Moss that would make a great weenie roast. ;)
/ To split, or not to split: that is the question. #8
Man that would cook a serious weenie !!:laughing:
/ To split, or not to split: that is the question. #9
Some species of wood will split much easier when wet. I split before I put it under cover. I usually split wood 5-6 inches in diameter and wider. Given that much of what I cut up for fire wood can be 2-3 feet in diameter, that's why I use my backhoe to lift the rounds onto the wood splitter. Not to worried about my firewood being dry as I have a good four year supply cut, split and stacked under cover. Most of my wood is fir with some hemlock and a bit of alder. :)
/ To split, or not to split: that is the question. #10
Put a wedge on that thumb Mouse and skip the splitter ! Some wood splits better when frozen as well. Plus you stay cooler ( no AC on my splitter) and the bugs don't bother you! :thumbsup:
/ To split, or not to split: that is the question. #11
Not sure if I really want another attachment, having trouble storing everything I have. :licking:
/ To split, or not to split: that is the question. #12
No kidding, guess the 'ol ladies shoes do take up less space !:laughing:
/ To split, or not to split: that is the question. #13
Not poking fun, but seriously, why? Other than this looking cool, what is the point? If you made normal stacks they would dry the same and take a whole lot less planning/building time i would think.
/ To split, or not to split: that is the question. #14
The smaller the pieces of wood the more surface area is exposed to oxygen and it will burn easier, hotter and much more efficient. Large pieces of wood have a tendency to build up carbon on the outside [low burning temp.] which does not allow oxygen access to the wood vapours so combustion can occur.:)
Some years ago there was quite some discussion on Holtz Hausen.:)
/ To split, or not to split: that is the question. #15
Birch I had in Montana never dried before splitting and if left unsplit for a couple years rotted from the inside out. OTOH, it was a bear to split.
Doug fir, pine and larch I have had split much easier when dry.
/ To split, or not to split: that is the question. #16
actually there is a very good reason, wood stack in this manner will dry much faster then in a "normal" stack some report in half the time. and it is much more resistant to falling over.
/ To split, or not to split: that is the question. #17
How do you cover it?
Thanks in advance!
David
/ To split, or not to split: that is the question. #18
Birch I had in Montana never dried before splitting and if left unsplit for a couple years rotted from the inside out. .
Yes birch with bark on will rot before it seasons.
Perhaps that implies that wood does season significantly through the sides.
/ To split, or not to split: that is the question. #19
I've heated with just wood since 1978. I used to split because everybody did. Then I thought about it and wondered about how many times I handled each piece of wood before it went into the stove. I also noticed that burn time was longer and easier to control unsplit. Now I use as big a piece of unsplit wood that will fit into the stove. The stove never goes out, just the ash! I always have a bed of coals. I burn wood that is dry- no sizzle (cut/stacked the year before- cherry, oak, maple, birch. Punky wood is not much good for heat.
I hate handling wood- there is always something else I could be doing- so no splitting. If is is too big- I use a maul. Maybe once or twice all winter.
/ To split, or not to split: that is the question. #20
Thanks in advance!
David
David, if you google building holz hausens you will find loads of information and explanations. To answer your question if built "by the book" it does not need covering because the top is slanted out with bark side up pieces forming the cover.
