My latest build--Mobile Chicken Plucker/Scalder
/ My latest build--Mobile Chicken Plucker/Scalder #1
Stranger
Member
Virginia
I just finished up this build for a local gentleman who desired a Plucker and Scalder set up. Luckily our compensation agreement allowed me some 'freedom' in the design and functionality.
So I came up with this...
/ My latest build--Mobile Chicken Plucker/Scalder #2
Wow, that is quite the setup! Is the plan to rent it out or offer a plucking service? We share a drum plucker with a neighbor but it tends to be a chicken skinner if you try to do tricky areas with it.
I read tub pluckers are better somehow but I'd like to see one work in person. We just had the gizzards for lunch from a couple meat birds who legs were starting to give out, so having any plucker sure helps the processing become less of a chore.
You'll have to post some videos of your machine in action.
I am going to assume the buyer will eventually offer a service.
I don't think he really expected this as the finial product because he had originally came to me with a rough idea of two separate units.
Tubs do a really good job but as with any plucking you need to have your scald correct!. This unit will maintain the water temp within 3 degrees of the set temp. For this application 143-144F works out perfect with 3 chickens dunking at a 6 time per min rate. You can knock out 3 chickens about every 2 min :licking:
I'll get some video and post it once I get to a higher speed connection.
/ My latest build--Mobile Chicken Plucker/Scalder #7
Just helped with 17 chickens, by hand... this would have been *really* nice!!! Are you going to into production with these? :laughing:
Looks like you used a water heater? How long do the birds stay in the Plucker? (other then 'when they're done' :)) Pretty cool setup... :thumbsup:
I build a lot of custom things... If someone wanted one of these or similar I'd build another. It takes less than 2 min for the whole process; a little over a 1min for the scald and around 20 sec to pluck...3 at a time.
The scald tank is made from a water heater but I changed out the controls to something more reliable and accurate. I used some ideas from others I found around the internet. Its all propane powered including the on-board generator.
Just hook up water and your in business!!
/ My latest build--Mobile Chicken Plucker/Scalder #9
Stranger, I'm a bit dense. When you say:
" 3 chickens dunking at a 6 time per min rate", just what do you mean? We use a washtub over a turkey fryer burner and go for 142 to 143F; so I'm trying to envision your dunking protocol.
Btw, I'm using a homemade drum plucker; would love a tub plucker someday. Great build!
Three chickens are clipped onto a carriage that raises and lowers 6 times a min. It's also moving slow enough to do test pulls of feathers to see if their ready for plucking. Here is a pic showing the whole scalding section to give you a better idea.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
New Holland 3930 (A60462)
New Holland 3930...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
