Walmart Hydrolic fluid
/ Walmart Hydrolic fluid #1
toxicjeeper
N.B Canada
LS 5020c
I have an unopened pail of walmart hydrolic fluid that i used to dump in my old 79 ford's loader..Is it OK to use with my new LS Tractor? I need to change the hydrolic filter for the 50 hour break-in change and was thinking about using it to top off any fluid i might lose..
Here is a picture of the hydrolic oil in question.
I also have another question about oil changes..On my old ford i could dump the MOTOR oil into the motor via this opening by the injector pump..is it the same with this LS? It seems to be dry inside that cap but i thought they shared the oil sump..Please see the picture..Thanks!
/ Walmart Hydrolic fluid #4
My manual calls that the "Oil Filling Inlet." The cap on the rocker cover is really in a tight spot under the hood.
/ Walmart Hydrolic fluid #5
There has been some talk about using the fill on the on the rocker cover that the oil can flow into the combustion chamber and cause the motor to lockup if started to soon before the oil drains down. I will always use the lower fill point.
/ Walmart Hydrolic fluid #6
If there were a path for that much oil to flow from the top of head into combustion chambers, that would be a serious design flaw. Oil is pumped up there the whole time the engine is running. Any extra oil up there should fall straight to the pan.
/ Walmart Hydrolic fluid #7
There are different types of hydraulic oil and each has a rating. If it's just for your loader, and not wet brakes or a transmission, then you are probably fine. With brakes and transmissions, you really need to make sure you use the correct oil. The picture doesn't show the list of types of machines that it's good for.
Eddie
/ Walmart Hydrolic fluid #8
Just one of a few.
MiserableOldFart said:
The TC26 DA is getting old enough now that there might be some owners out there who are not original owners and not on the mailing list from CNH, so I thought I'd put this up as a warning: There is a service bulletin out on oil: When you add oil, or change oil in the TC26DA (don't know about other models, but it would seem logical that at least the TC23DA would have the same problem.) Be VERY careful to pour the oil in S-L-O-W-L-Y. I also would take the precaution (that seems logical though for all I know it might make things worse) of having the engine well warmed up for oil changes so that it's still warm when you replace the oil as well.
Apparently, pouring the oil in fast (as the very large oil fill invites you to do) can DESTROY the engine. I also take the precaution of, after filling slowly, letting the tractor sit for 10 minutes or so to allow all the oil to flow into the oil pan, then checking again for level before starting.
The service bulletin came as a total surprise to me. I had changed the oil a couple times myself after the dealer did it the first time.
Just went down and got the bulletin. Hadn't seen for a while and it indeed covers a whole bunch of models. The number of the bulletin is 0606-T3 and it covers TC23DA, TC26DA, TC30, TC35A, TC35DA, TC40DA, TC40A, TC45A, TC45DA, TC48DA, TZ18DA, TZ22DA, TZ25DA, TC29DA, TC33DA, MC22, MC28, MC35, and commercial front mowers.
I think someone put a thread about this up in the past, but there is always the chance of new owners of used machines out there that haven't seen it.
There are further instructions in the bulletin regarding how to address the problem if you believe oil has gotten into the breather valve into the intake manifold and cylinders.
/ Walmart Hydrolic fluid #9
I wish that post would have explained exactly how the oil gets to the combustion chambers. I like to understand things like that.
/ Walmart Hydrolic fluid #10
I not sure what model you have. I have a U5030 gear this is the fluid I use and got from my dealer it what shown in the manual this is the list of compatible oils.
/ Walmart Hydrolic fluid #11
I wouldn't I wouldn't I wouldn't!! Burned up a mower conditioner pump on that stuff one Sunday when Wal-Mart was the only place open to get oil. It's not like you have to buy it that often anyway, and if you do fix the leak. These machines are too expensive to use cheap oil.
Thanks for the replys fella's. I think i wont be using the walmart oil. Like ozley mention it is a shared sump between loader, trans, brakes. etc..I will just pick some oil up from my dealer before i change the hydrolic filter for the 50 hour break-in period..
As for the motor oil i did reach way back and fill from the top of the motor..definitely wont next time but only because it is such a PITA to reach it..also fought to get the oil filter off..even with a screw driver threw it i couldnt get it...wasnt enough room to spin it:mad:..got it eventually with a really mean set of plier looking filter wrench i borrowed from a friend..
forgot to mention i have a model 5020 LS
/ Walmart Hydrolic fluid #14
That wasn't me about the oil and wet brake warning that was Mr Walker. What he said is very true glad you took his word.
I used a little over a gallon changing the filter but I am slow.
My Bad meant to referr to EddieWalker's post..
I figure i will lose about the same amount, Dealer sells it by the gallon or 5 gallon.
2016 Takeuchi TW65 Mini Articulated Wheel Loader (A61567)
2016 Takeuchi TW65...
2019 CATERPILLAR 226D SKID STEER (A62129)
2019 CATERPILLAR...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
Semi Trailer (A61568)
UNUSED SDLANCH SDLE20 MINI EXCAVATOR (A62130)
UNUSED SDLANCH...
JOHN DEERE 50P EXCAVATOR (A62129)
JOHN DEERE 50P...
