Snow Need a snow blade for my 5035
   / Need a snow blade for my 5035 #1
NewGuyInNewEngland
Canterbury, Connecticut
Mahindra 5035
Hello All,
Been a long time since logging on. Crazy spring summer with being away in NC for training for new job. But home for the winter so time to research a snow blade for my 5035. Coming up to the 50 hour maintenance and have inquired about a snow blade to my dealer, so would like to go into the conversation/negotiation informed before having him do the maintenance and snow blade install in one pickup/delivery charge.
I will be 55 next Sunday and from what I have read so far, the older one gets, the harder it is on the neck and back to keep turned in the seat when using a rear blade. My driveway is only about 300 feet long but has a fairly good incline and gradual curve also, is narrower near the top and opens up the farther down the hill I go, so thinking some sort of FEL blade with power angle capability. If this winter is anywhere close to last years, I will need to use the bucket to move snow before it freezes if I run out of room to push it, which is a distinct possibility. I may be overly concerned as the 5035 is very powerful, has 4wd with the rear wheels having lockup capability with the foot pedal. I may never have to swap to the bucket, but just in case.... :confused3: Is it possible to get a blade with angle capability that can be swapped with the bucket as a quick release function? I know this is going to be a bit pricey, but I have learned the hard way to do it right the first time or I'll be sorry.:mur:
I believe the plow blade my dealer sells/recommends is not a Mahindra product. I vaguely remember the cost was around $2k but somewhat more (of course) with angle capability ($350+?). I have been advised to fill the rear tires for the added weight. Leaning towards beet juice, which is popular around here in case of a leak. More eco friendly, plus less expensive than rim guard.
That's all I know and it aint much.
:confused:
Any input would be greatly appreciated.
I attached a pic of me and my beast from back in April when I put her to work.
Thanks.
Gus
   / Need a snow blade for my 5035 #2
Hello All,
:confused:
Thanks.
Gus
The price you were quoted for the front blade sounds reasonable to me. I would certainley load the rear tires, as the plow is heavy and also puts the load out front further.
I would also load the front tires as steering with the blade angled is difficult. It should be a nice setup, good luck with it.
Test Button (A47384)
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
