Creekbend, As with many things, the answer is "It depends", and upon many possibilities, mainly your own treatment of the young plants, but an important factor appears to be (anecdotal evidence only) the treatment of the cuttings up to the point you buy them. Growth of the trees you purchase can be influenced a great deal by the cuttings raiser - push them along so they reach selling stage faster, or hold them back for a sturdier plant. It is difficult to tell the "age" of the cutting when you buy it, but for an example, I bought 277 trees of two varieties in 2006, and from two suppliers. The varieties were Negrinha do Freixo and Cobrançosa. You are not likely to come across Portuguese varieties in USA. The Negrinha is yet to produce anything, and the Cobrançosa from the same supplier have very few bearing fruit as yet. The other supplier's Cobrançosa are mainly fruiting a small quantity. I topped up to 299 (regulations mean seeking permission to plant) in 2009 from a third supplier, using Cobrançosa and a few Cordovil de Castelo Branco. I had lost quite a few trees to a minus 7ºC frost the previous winter and filled the gaps with the Cordovil. Most of the new Cobrançosa and Cordovil are fruiting. I planted another new grove of 141 with Cobrançosa and Cordovil in the early Spring of this year, and almost all these trees are carrying a few ounces of fruit. The average size of all trees I bought was around 3 feet, and they came in pots of one or one and a half litres. Spacing is 6x6metres.
Psient, I drafted the response to Creekbend before I saw your post #7. No offence taken I hope, but the timing of first production is very variable despite what you read. I think Rox probably eventually realised that the cost of setting up her own equipment was not economic with her 1360 or so trees. I sell as much of my production as possible for table olives to a local buyer. This means I pick the fruit by hand to obtain better quality. There are many olive mills in the area, several within 20 miles, and lesser quality fruit goes for oil. I know one of those mills took in more than 4,000 tonnes of olives two years ago.
At the same time, I would be the last person to put you off making your own mill, in fact I would encourage it if there are no nearby mills. What I would do though is to go for the old-fashioned method. Grinding is far better than hammer milling. You want a smooth paste for pressing, not a hammer milled product that will have small pieces of pits in it that will not press. There is oil in the pit too and that is why grinding to a paste has always been done. The pits are often removed from table olives sold commercially (I use a cherry pitter for my own) and so are indeed a surplus that can be burnt – very similar to corn cobs being available I suppose – and I use those too. On a small scale I think cleaning out the hammer mill afterwards would take more trouble than the oil is worth. After grinding, use any sort of press you can come up with and then float the oil out of the water in a barrel or similar.
I will send a PM to you both with more specialist links, maybe not today. For general reading from a US site, see
The Olive Oil Source | Everything but the Olive and although it is incomplete with promises of “coming soon” it is still a very good and informative site.
I am not sure how far I can go without breaching advertising rules, but will take a chance on this paragraph being deleted by the Administrator. I recently published a long eBook “How not to make Millions – but still live a rich rural life” that gives a small amount of additional information about olives in Europe. Olives are not a specific topic in the book, so the information is not concise enough to copy it.
