3-Point Hitch Is there an easier way to attach equipment?
   / Is there an easier way to attach equipment?
It has an pull up knob on the fender along with the cruise control both factory installed along with the 305 loader, I've tried both ways, no luck. I have a 4 ft Taylor tiller & a 5 ft Big Bee mower. Thanks for all the suggestions. I really like my popping johnnie other than this one issue. Mary
   / Is there an easier way to attach equipment? #12
I think that will work just fine. Now I know what it looks like when I stop at Tractor Supply. Some one earlier said that they also have them. Some of the young guys there never been on a tractor. Thanks a lot.
   / Is there an easier way to attach equipment? #15
NO Problem. If you get one, get the type hatc click into place by pulling back the sleeve. Some of them require a pin to be drilled into it...skip that kind. Mine hooks on and off in seconds.
   / Is there an easier way to attach equipment? #16
OK will do, easier the better, thanks all. Mary
   / Is there an easier way to attach equipment? #18
If she was to install this would the shaft need to be shortened?
It adds 6" overall to the length. Most shafts can shrink down without cutting. I personally HATE to have to cut a shaft.
The quick hitch adds about that much extra length, so I don't think I'll have to do any cutting. I found I have to raise the mower a little because of the extra length so I can get it on the PTO. My neighbor and worked for over an hour on trying to hitch it up the first time. I stepped back and looked at the angle & when we raised it, it was easier getting on.
Now that you helped me solve that problem, I dug up an old part off of something, looks like a step on on a wagon or some other equipment. I have a couple of pictures posted on Grit.com blogs
Hummingbird Migration, Daylily Photos and a Mystery Tool
   / Is there an easier way to attach equipment? #20
If me, I would try turning the key on (do not start) and engage the PTO. Then see if that releases the PTO brake on the shaft.
1667 (A57192)
1667 (A57192)
Miniature Metal Goat Statue (A55853)
Miniature Metal...
Transport Frame Mini Skid Steer Attachment (A55851)
Transport Frame...
2008 Ford Crown Victoria Sedan (A55853)
2008 Ford Crown...
UNUSED SDLANCH 72" QUICK ATTACH BUCKET (A57193)
UNUSED SDLANCH 72"...
2007 MACK CL DAY CAB (A57880)
2007 MACK CL DAY...
