Which Rattle-can Paint is closest to Kioti Orange?
   / Which Rattle-can Paint is closest to Kioti Orange? #21
I don't know anything about "old Kioti", but current Kioti has more red than either Kubota. Again, Chevy engine orange was a dead ringer when I needed that shade for my RFM. When tried it to touch up a Kubota implement, it was far too red.
Old Kubota was a dull, yellowish/brown orange, if that makes sense. New Kubota is brighter, more vibrant orange, but doesn't have the red tint of Kioti.
   / Which Rattle-can Paint is closest to Kioti Orange? #22
Hey Pack,
Took my grill guard off to start working on it. I washed it down and turned it over to try a little experiment. I taped off the side of the attachment plate that goes against the frame. Here are some of my photos showing before and after pics. I used a can of the "Chevy Engine Orange" enamel. Here we go.....
Before....
   / Which Rattle-can Paint is closest to Kioti Orange? #23
Here are the after pics....
(in the first 2 pics, the original paint is on the left, rust-oleum on the right)
   / Which Rattle-can Paint is closest to Kioti Orange? #24
I used Rust-Oleum's Chevy Engine Orange. It is sooo close to the factory color!
After letting is set for several hours, I noticed that it doesn't have quite the sheen that the factory paint does, even though it is an enamel finish. I would probably suggest a can of clear to give your paint work a nice glossy finish if you are going to use this paint.
I plan to add expanded metal on the outside to prevent debris going thru it and damaging the front of the tractor.
Hope this helps you......
Greg
   / Which Rattle-can Paint is closest to Kioti Orange? #25
Greg
Nice work! Looks factory from where I sit!:thumbsup:
Expanded metal? - can you say more about this and how you are planning to use it / pics too, if possible? ( I just found out I pushed something through the grill, don't know what or when, but I did it some fairly serious damage). :(
Didn't do anything that can't be fixed though...:cool:
Thanks.
CM
And to the op- thanks for this thread.:D
   / Which Rattle-can Paint is closest to Kioti Orange? #26
CM,
First pic is expanded metal. This is a heavier grade than what you will find at Lowe's, Home Depot, or TSC. This is a quarter sheet and cost me about $22. Second pic is me just laying it down on the guard where it will go on the outside....a reference photo. I will have to cut it to fit and contour it but I will take and post pics while I do it.
I busted the plastic grill (below the headlights) with debris when using my pallet forks.
   / Which Rattle-can Paint is closest to Kioti Orange? #27
CM,
That's exactly what I need to do too!:D
Looks like a step up from hardware cloth.:thumbsup:
That is definitely a vulnerable area and hard to know when things are attacking it when one is working the machine.:laughing:
Thanks for the pics- will be interested in how you attach it to the "brush guard" ha)- doesn't really guard anything the way it's designed.
Keep up the good work!
Thanks.
CM
Packmate CM,
You're welcome! :thumbsup:
Packmate Greg,
SOLD! You have convinced me! This "Ford Guy" has a newound LOVE for Chevy Engine Block Orange! A can of this will soon appear in my shop and "Kioti" on tape will cover the word "Chevy" :D
Ammo cans etc in this "Kioti" color will soon appear also!
PS - I too am VERY interested in your addition to the brush guard idea (except I have no welder :() I hope I can come up with a different attachment method. Luckily I have not hit the tractor directly dealing with this mess [see pic] but I did break a $150 hyd line & lose a nut on the grapple when a 12' cedar came straight back thru the grapple...
Where did you get the material?
Thanks to all!
Be well,
David
   / Which Rattle-can Paint is closest to Kioti Orange? #29
Hey Moss, get you a MIG welder.... learning isn't that hard ......even a caveman can do it. Most community colleges have classes, or you can read up on it and bungle through until you get it right like I did. I bought a MillerMatic 210 before I retired off Craigslist. It has paid for itself many many times already in a little over 4 years.
Oh, and Millermatic....they are FORD Blue;)
   / Which Rattle-can Paint is closest to Kioti Orange? #30
Packmate CM,
Packmate Greg,
Thanks to all!
Be well,
David
Having trouble seeing the pic of the damage?!:)
Be careful- the grapple can get one into some trouble- ask me how I know!:D
BTW, I don't think you'd necessarily have to weld the brush guard screen onto the guard- but let's see what teh designer comes up with first.:thumbsup:
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
JCB 214 SERIES 3 BACKHOE (A51242)
JCB 214 SERIES 3...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A52128)
John Deere 752...
HYD MULCHER HEAD (A51243)
HYD MULCHER HEAD...
