Front-End Loader Worst things to do to a FEL
   / Worst things to do to a FEL #41
This thread looks like my diary entry for last weekend.
The first thing on my list of "must have's" when I bought my tractor was a cup holder.:)
Are you aware that it is aginst the law to operate machinery while drinking?
That I why I always make sure I come to a complete stop, turn tractor off, take drink, and then resume my business:laughing::laughing:
   / Worst things to do to a FEL #42
Also remember if you put something in your bucket like chains, chainsaw etc and forget about them when you start digging into a pile of gravel. I know many people whom have done this... :eek:
   / Worst things to do to a FEL #43
Anyone with some wisdom?
ac
Even when using bucket in float mode, I would not back drag with excessive tilt angle. And of course, when in float mode wheels are always on the ground.
It is also more effective to back drag with a load of dirt, or rock in the bucket. That requires the bucket to be curled back so materials don't fall out.
   / Worst things to do to a FEL #44
Good one:D While out working years ago I asked one of my girls if she knew where my chainsaw went....she said "dad you buried it". I said oh yeah I knew that.
   / Worst things to do to a FEL #45
When carrying heavy loads with the loader keep the load as low as possible and keep your hand on the loader controls. If you start to flip on uneven ground you can panic drop the bucket. This usually happens somewhere between the pucker facter and your shorts getting filled!
   / Worst things to do to a FEL #46
Don't asymmetrically load it either with a chain or by pushing. Don't use it as a bulldozer or to ram things. Don't push tree branches or tree trunks that can act as a huge spring and take your head off. Don't push over trees which can break off high up and crash down on you. Don't use it without adequate rear ballast. Don't transport weight in it when elevated. Don't lift heavy objects when on a surface inclined perpendicular to the tractor. Don't ride people in it.
When used as a portable beer cooler, put the ice in before the beer.
Good advice on use of the FEL though frankly I don't mind digging through ice for my beer.
Also, regarding transporting with weight in the bucket. Surely you are correct it should not be elevated to full height or even above chest level but elevating a few feet off the ground is no problem and safer than "skimming" the ground with a load.
   / Worst things to do to a FEL #47
Not me, I hate cold hands. :laughing:
Right. Once I screwed up and accidentally put the loader in the float position while on the move. When it came to the ground I just about went over the steering wheel. :ashamed:
   / Worst things to do to a FEL #49
After reading some of these Don'ts, I'm wondering if attaching a snow plow to the FEL may risk bending or distorting bucket arms?
   / Worst things to do to a FEL #50
In theory yes. The long arms of a tractor FEL are far more vulnerable than the short stubby arms of a bulldozer or the spring protected arms of a pickup truck plow. Still there are not too many damage reports which is probably because most snowplowing with CUTs is done on known asphalt surfaces with little risk of a high energy collision with a sewer cover or curb etc. No doubt though, a CUT FEL would be much more easily bent in such an impact.
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
More info coming soon! (A55787)
More info coming...
2023 JOHN DEERE 325G SKID STEER (A52707)
2023 JOHN DEERE...
2004 Mack CV713 Granite Fuel and Lube Truck (A55852)
2004 Mack CV713...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
