Trailer conversion
/ Trailer conversion #1
lstinthot
Spotsylvania, VA
CT230
What's involved with converting a 7000# trailer to something with a little more capacity. I have a 16 foot diamond deck car hauler rated at 7000#. I believe I could just swap the axles and upgrade the tires. Am I missing anything. Already has brakes.
Thanks
/ Trailer conversion #2
Often times the tires and axles are the weak link but the frame of the trailer may not be designed to hold any more than that either. I have been down this road before and you usually are time and money ahead to just sell it and buy a heavier trailer. All the conversion parts can add up fast.
/ Trailer conversion #3
5200# axles with brakes are $350 each. Springs, hangers, etc will run about $250 for the whole set. Wheels and tires maybe $180 each. I assume you want 5 including a spare. Total cost $1850. Figure in your time and you would probably be better to sell your trailer, put the $1850 you would have spent with it and buy something stouter all the way around.
I have been offered close to $2000 for my trailer, looks like take that with another $1300 or so I could have a new one. Thanks for the break down.
/ Trailer conversion #5
Make sure you find another one before you sell yours...
David from jax
/ Trailer conversion #6
Hitch coupler probably needs an upgrade, too.
/ Trailer conversion #7
In August, 1990, I had that done to our 32' fifth-wheel. It was built with 3500# axles and I went to the Dexter factory in Elkhart, IN, and ordered custom built axles; 5200# axles but using the 6000# tubes (2" x 2.50"), bigger brakes, springs, shackles, nuts and bolts. But it would not be worth it for a utility trailer.
/ Trailer conversion #8
If your 7K trailer has the Mfg. ID and rating tag on it your state may not let you raise the weight limit above Mfg. specs. There is a lot more involved than swapping axles and tires for Mfgs. to get a certified rating on trailers.
Best to sell the 7K and look for a trailer with the capacity you need.
/ Trailer conversion #9
I'd be willing to say the frame wouldn't hold up, plus like George2615 wrote your state may not go along with your idea.
/ Trailer conversion #10
Totally agree. Besides, if you wanted to sell that trailer later, as a buyer, I wouldn't want to buy a trailer that someone else has converted.
Thanks for all the replies. I think I will look for a larger trailer. Dealer believes my trailer is big enough. I just think it is pushing the limits. I just bought a CT230 tires filled with backhoe and FEL. Just guestimating, looks like the setup weighs 5700#. It is only 16' long so a longer higher capacity trailer would be better.
/ Trailer conversion #12
I think that is a wise decision. Good luck.:thumbsup:
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
(2) RAM 7000 LB TRAILER JACKS (A64280)
(2) RAM 7000 LB...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
