Original brochures
/ Original brochures #1
284 International
International Harvester 284
In another thread, Scotty Dive posted some information about the original loaders on some Yanmar tractors. He sent me some scans of brochures he has made. I've posted them here on my photobucket site.
There are brochures for the GT14, YM169, YM180/187, YM220/226, YM276/336, and a Brantly Backhoe, with a couple pages from a Yanmar 650/656 hoe as well.
Scotty Dive gave me permission to post these, so I converted them from .pdf to .jpg, and now they're available to whomever may find a use for them. Again, they are not mine, but he agreed to let me share.
Thanks, Scotty Dive! :thumbsup:
/ Original brochures #2
Cool - Now you will have to tell me how you converted them from pdf to jpg!
I used the online file conversion service Zamzar.
I hope they're useful to people.
Some interesting observations in the little bit I've glanced through them: The YM169 has a tremendous 3 point lift on it. It's rated, according to the brochure (which I don't really trust), to lift only 66 lbs less than the much bigger YM226, and only a few hundred pounds less than the brawny YM276.
It's rated to lift more than my YM186D, the next size up, with a notoriously strong lift. I see the 169 has the same pump as a 1610.
If people are willing to contribute, I'll start compiling a table of hydraulic pump capacities of each model, since that seems to come up regularly.
With all the hydraulic projects going on, and with some scheming for my own plans in the works, I thought maybe we can start a list of pump flow ratings as actually mounted on the tractor. I read this information off my tractors. I took the following information about displacement per revolution off the data plate on each pump, and calculated the flow at rated engine speed using 1 gallon = 3780 cc.
YM1401D: 4cc/revolution 2.75 GPM at 2600 engine RPM (Interesting, because the replacement part calls for the same pump as the YM186 series, with 75% (!!!) more flow)
YM186D: 7cc/revolution 4.8 GPM at 2600 engine RPM (Agrees with brochure)
YM2000: 7cc/revolution 4.4 GPM at 2400 engine RPM
YM240: As YM2000 ( Other sources mention a high volume, 9cc/revolution pump as being an available option, giving a flow of 5.7 GPM at 2400 RPM.)
YM240D: As YM2000
Taken from sales brochures:
YM140/147: 3.4 GPM at 2600 engine RPM 5CC/revolution
YM180/187: As 186D
/ Original brochures #5
OK 284, here is what is on my ym2002d pump. Kanzaki pump, model gp1c10csp, mfg no.2A0020, pressure 160kg/cm2, discharge 10cc/rev. For what it is worth department the 2002d has power steering. According to my parts book the correct part # for this pump is 194361-41120. Not sure about conversions, am I correct that the pressure is 2277psi? Am I correct thinking at 2400 rpm the pump should put out about 6.34gpm? I appreciate you undertaking this task.
/ Original brochures #6
RE: Hydraulic pumps
Does anyone know what our mounting face is? or have pictures of one they have pulled. I would love to upgrade my pump and would like to look for all possible options....
I have a 1602D with a Kanzaki GP1-C-5 which is 5cc/rev or about 3.3gpm at 2400.
/ Original brochures #7
Very cool brochures! I have never seen a 169D so clean! :laughing: I see they offered them with a FEL, also good to know. :thumbsup:
/ Original brochures #8
I have the sales flyer from the 186D that I have, I will try to scan it and send it to you in the next couple of days if you wan't it.
Pete, that sounds good. I already have one posted here though. If it's different, I'd love to see it. It's also possible that it was updated over time, or is from an earlier version (the tractor I have is a floor shift, and the one in the brochure is a dashboard/column shift).
/ Original brochures #10
You have to be careful comparing lift capabilities - or any specifications - from compact tractor market of the 1970s and 1980s. This was a period where a lot of Japanese tractor manufacturers were vying for the the US compact tractor market. Most of them were publishing advertisements playing fast and loose with specifications. Specs printed in advertisements of the time were often different than the ones printed in their own technical manuals. The advertised numbers were "true" but were also deliberately deceptive since they required a special non-standard interpretation of how these things are measured. HP, loader, and three point lifting specs were favorites. Some Japanese machines were tested at Nebraska and this resulted in an industry outcry. To Yanmar's credit, they were one of the first to publish amended figures. The YM186/187D just might be my favorite ever tractor and the correction to the YM186D specs is in their service bulletin T-020 sent to dealers and dated July 2, 1981. In the service bulletin the advertised lifting capacity for that model was reduced by 38% in order to "select the correct liftable implement". Corrections to other models followed, but I don't know if they ever got around to the later models such as the YM169D. The YM186D correction wasn't all that public or easy to find. And interestingly, Yanmar couldn't resist taking a swipe at the competition in a note appended to the service bulletin.
Enjoy! rScotty
/ Original brochures #11
Enjoy! rScotty
I am not sure they did on the 169D, the 3 point hitch can lift the front end right off the ground without weights out front.
/ Original brochures #12
Yep. This turns out to be exactly one of the ways to pump up a rating that I was speaking of. Obviously it doesn't do any good to lift the front. And so traditionally manufacturers had set their pressure cutout to prevent that from happening. The other way that the specs at that time were misleading was that the lift point was calculated at a different location than where the mass of the implement was located.
None of it stops the YM169D from being one of the best little tractors ever. Tremendously sophisticated for its size.
enjoy, rScotty.
/ Original brochures #13
enjoy, rScotty.
Here are a couple examples of it's lift power. I had to add 200 pounds of weight to the front in order to lift the log with my pallet forks. The photo with the box blade demonstrates lift without front ballast. :confused2:
/ Original brochures #14
I have a box blade too; but with a FEL for counter balance; notice; the more weight you (one) puts the further out the more unstable or more counter weight needed. The 3 pt hitch attached to your box blade is out further than most; so more counter balance will be needed ...
/ Original brochures #15
Anyone having problems reaching the brochures page the 284 included in the first post?
Hmm, sorry about that. I'm not sure what the issue is. All of the organization seems to be fouled up at Photobucket.
I will post the entire hyperlink to the parent folder. The lower right corner has options in the "Sub-folders" window to "view all folders." That will take you to a list of each brochure grouped by model.
Yanmar information pictures by International284 - Photobucket
Domush has a great explanation about how to use Picasa, and shows how one can change the display size of the picture in the link itself. Find it here. I will eventually transfer all my stuff to them, I think. Photobucket was nice to use and easy, but I have noticed a couple other links of mine have disappeared, too. I'm not sure what happened, but I'll experiment with Picasa, I think, on this next project.
/ Original brochures #19
Thanks 284!
Rscotty - there was a thread recently where a new user was looking for tires sizes and I offered to email him the brochure I had but its 9 megs. It would be great to have yours scanned and out on the web for posterity....I doubt you have one for a YM 2020 though!
/ Original brochures #20
I help where I can. My literature is largely old sales brochures for the US model Yanmars. And also factory service info plus some specialized implement literature for "Yanmar branded" implements sold here back in the 80s All US stuff; nothing grey market. I've a suspicion that the US Yanmars were mostly the same as the international ones, but with different model numbers. And then there are some -like the YM336D - that were sold worldwide under that model designation. The last new US models were introduced here in the mid 1980s. I think the later models here correspond to the xx10 grey market models but not sure about the xx20 models. I'm not clear myself what the difference is in the YM2010 and the YM2020.
rScotty
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
Case IH 820 Rigid Grain Platform (A66408)
Case IH 820 Rigid...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2012 C&M TRAILER 16' ENCLOSED CARGO TRAILER (A65643)
2012 C&M TRAILER...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
