What strange things have you moved with your loader..pics
   / What strange things have you moved with your loader..pics #181
Took a 200 lb+ desk out a 2nd storey door last night. (stairs aren't in yet). Set the forks in the door frame and slid the desk out.
   / What strange things have you moved with your loader..pics #182
Dont know if it was strange, but I used my hay fork on my JD 4430 to lift some 28' steel pipe rafters into place as I was building my barn. To get the height I needed I slipped a 10' piece of pipe over one side of the hay fork. To the pipe I welded two anchor points at the far end for a chain, one to attach the load and one to the top of the hay fork frame to take some of the load off the fork. The high point of each rafter was 15' above ground. Each rafter weighs about 350 lbs.
   / What strange things have you moved with your loader..pics #183
Building a roller. Body is 3/8" thick steel pipe 18" in diameter by 6' long. Weight is around 550#. It had to be stood on end to mark it square for cutting. Then laid back down for the cutting.
   / What strange things have you moved with your loader..pics #184
I use the tractor to shuffle my hog traps around. I guess they weigh around 250 pounds or so...
   / What strange things have you moved with your loader..pics #185
Put a deer where that hog was a few posts back and that's the strangest thing I do with it every year. When my daughter was two, she asked why the deer was chasing the tractor. An odd way to chase a tractor I thought, but I just said the deer really likes the tractor.
   / What strange things have you moved with your loader..pics #186
Last winter the the kid across the road got his dad's 3/4 ton Chevy pickup high centered on a rock next to his driveway and I picked up the pickup truck with my forks (on the 105) and got it off the rock. I was surprised that I didn't damage anything underneath but Chevy's are tough....I guess.:)
   / What strange things have you moved with your loader..pics #187
Dfkrug, can we get a picture of how the axe is attached from the drivers perspective?
I could not find the old thread on gun racks, so here is my axe-holder. It's
a couple of rings cut from 3" sched 40 steel pipe, painted orange, and
bolted to the FEL cross bar. Padded with foam inside.
This 2500-gal PEX water tank is my biggest loader load. I carried it
almost a quarter mile, very slowly. Only about 600# or so, but bulky.
   / What strange things have you moved with your loader..pics #188
Did you drive backwards so you could see where you were going, or were you able to use the road's edge as a guide, or did you have a spotter?
   / What strange things have you moved with your loader..pics #189
Yeah fwd visibility was not the best....I watched the edge of my
private road and went really slow. Forward. I figured if someone came up
the road, they would see me and have to back down the hill.
   / What strange things have you moved with your loader..pics #190
Here's my contribution...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2020 CATERPILLAR 289D3 SKID STEER (A52709)
2020 CATERPILLAR...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
