Gobblin Tom
Gold Member
I have had my 2520 for a while now and have been reading a lot about the Float feature. Is this on every tractor? How do you know?
not all FEL's have that feature.if you have that feature,when you place the loader in the full down position,push the control leaver completely forward,it should then lock into position.this enables the loader to,"float",without having any down pressure on the loader.this is a nice feature for doing grading work.
put your bucket on the ground then do a quick snap forward with your control...you should feel it catch and stay in that position -
i place the loader on the ground and then just give the lever a quick motion forward to engage the detent.if you try to engage the detent with the loader in the air,it will slam to the ground.it relieves all hydraulic pressure to enable it to float.never tried to use the curl or dump feature when in float position,but i imagine they would still work.not necessary to use those when you are grading anyway.
Does the JD loaders really slam to the ground? my Kubota does not. It would take 2 to 2.5 seconds to go to ground from full height. (why you would do that I dont know) but on the video I posted you can see I float the loader while still traveling forward and it takes a fraction of a second for it to hit the ground. You can hear the oil moving thru the valve as a "hissing sound"
James K0UA
When the tractor was new, it almost felt like I was breaking something in the SCV when I pushed it forward to the float position. After using it a while, it felt more like a detent, and became easier and smoother to operate.
Oh without a doubt it would hit the ground hard and fast loaded. No I have never tried it with anything in the bucket. I have always used it empty either for backdragging or pushing snow.Have you tried this with a full bucket of dirt?
James K0UA
I am concerned that the OP doesn't know this. Not knowing the float feature could be a concern if he accidentally hits the float with a full bucket and the loader fully raised.
