BX cruise control. Do you use it?
/ BX cruise control. Do you use it? #1
Haywire
Central Kentucky
Tractorless :(
Anyone use the cruise control that the BX is outfitted with? So far I have not had a use for it.
Ian
/ BX cruise control. Do you use it? #2
Never used mine either. Bought new in 2004
Take Care,
Doug in SW IA
/ BX cruise control. Do you use it? #3
Yes, while mowing long stretches.
Deano
/ BX cruise control. Do you use it? #4
I've used it to go up and down the drive way and lane .Do you
find it doesn't lock to the speed you were doing when selected
but rather it goes slower ? Maybe it's an adjustment somewhere
that's a bit slack .........
/ BX cruise control. Do you use it? #5
I installed one on my BX23, and yes I use it. Gives the leg a rest on occasional long hauls in low gear on rough paths. Use it when mowing too.
/ BX cruise control. Do you use it? #6
My B3030 wouldn't hold when set, called dealer when it was new, he wasn't any help, there is a threaded rod with two nuts locked to each other located along side the right rear tire, I adjusted it, still not holding, but it was better, I removed both nuts and inserted a washer to gain more spring tension, now works great. I have used it when mowing, but have read it's main purpose is when using swing brakes, I read that when using both brakes it disconnects cruise and I tried it, it does. Also read lock either wheel alone and it will not disconnect, haven't tried it, makes sense, otherwise why have swing brakes on a hydro.
/ BX cruise control. Do you use it? #7
I used mine alot when I first got it for mowing and tilling. now I don't and only time I use it is running down the road with BX.
/ BX cruise control. Do you use it? #8
Yep, sure did before my wife took it away from me.
/ BX cruise control. Do you use it? #9
i have not...however, i am still amazed and having fun with HST drive versus my gear drive i was used to...
/ BX cruise control. Do you use it? #10
Do you
I only use it occasionally, and this is why...
/ BX cruise control. Do you use it? #11
I don't use it for finish mowing but I do use it for brush hogging. At my age holding my foot on a hydro pedal in the same position for six or seven hours will cause my right leg to cramp. It would be the same as holding an accelerator at the same position for six or seven hours on a car or truck. Staying the same position for many hours is uncomfortable. The cruise control allows my legs to be free and I can move around in the seat before rigormortis sets in.
/ BX cruise control. Do you use it? #12
Hi all,
I use any time that I drive Jinny over to my friends places. They live about 1/2 a mile away so it is a foot saver.
~Kevin
/ BX cruise control. Do you use it? #13
Count me as a no - in fact I forget it even has cruise control so thanks for reminding me. LOL
/ BX cruise control. Do you use it? #14
I used it once right after I got it and the cheezy little pot metal "dogs" broke, so I figured it wasn't worth trying to keep it fixed. have always aimed to make some out of steel, but was never a very high priority.
/ BX cruise control. Do you use it? #15
I have had my BX2230 for about 3 weeks now, but still haven't gotten an owners manual. Does mine *HAVE* a cruise control? I haven't figured it out if it does.
/ BX cruise control. Do you use it? #16
Hi this is exact whats holding me to buy a BX. I use a Iseki with manual gear to spray my crops (strawberries). I can set the speed exactly right (have installed a bicycle speedometer on it). e.g. 1800rpm in gear 2 get me to the correct speed....the correct amount of fluid (nothing left at the end of the field)
Can the cruise control be used in the same way?
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
