Do you use a cutting area for Bucked logs?
   / Do you use a cutting area for Bucked logs?
I bring four foot lengths from the bush with the tractor and I have used a sawbuck to block for years (see link). How to Build a Sawbuck for Cutting Firewood - wikiHow
studor,
I like the idea of the sawbuck, but I'm going to be bucking pretty big logs, maybe 12 footers, not sure. I've got SO MANY downed trees right now...
I'm going to look at building a larger version out of some scrap lumber I have... We shall see how it works.
Be well,
David
   / Do you use a cutting area for Bucked logs? #22
Get yourself a cant hook, and save your back. (And your chain.)
   / Do you use a cutting area for Bucked logs? #23
Some have more experience than I. Been sawing and bucking fire wood for the last 20 years.
My notes:
1/Safety,safety,safety!
A: eye, ear, head protection
B: take your cell with you or a two way radio/walkie talkies if you have them or a whistle if you are within ear shot of your house - explain to spouse or others 3 whistles means HELP/emergency!
C: When you get tired - STOP!
D: Bring and drink lots of water... beer or whatever is after you shower and relax admiring the stacked pile.
E: Be aware of others around you and your environment
2/ More safety! Pants or chaps a must plus steel toe boots or chainsaw boots. I also wear a good tight fitting pair of gloves. I use pants and do find them hot in summer so I usually wear shorts under them. The pants show the signs of doing their job. Wear them - even for that quick little job. If you don't sh*t can happen - I know!
3/ I generally cut the logs when piled. I have also built a number of sawbucks over the years - small to big ones - but find moving logs to them is an extra step. I do use them for smaller branches. I also made small sawbucks which hold the log about a foot off of the ground on one end. If you build one make the vertical parts are the correct width for your stove - ie:18" for stove length.
4/ I usually mark the stove length on the log before cutting it up - I use the saw to do this and like others I use a length on the bar for reference. I also use the cut halfway method and roll with peavey to finish the job. This will save your chain and bar a lot of wear.
5/ Clean your mess as you go - it will save time in the long run and prevent accidents.
6/ Have fun! Once everything is chunked and ready to be split I get the family involved.
It's amazing how fast the work will go when four people are involved!
Play safe
   / Do you use a cutting area for Bucked logs? #24
Elvis was alive when I started cutting fire wood.I cut it on the ground where it hits. I figure the fewer times I touch it the better.Now I am in the south(an no snow to worry about)I split it an Leave it in the woods till I need it.When I cut it I always cut the small end using this as starter an work to the big end as i get to the big end I cut till the blade pinches an cut again, then turn the log an finish cut. I have a really bad back so holding the saw up any longer that's necessary is out of the question. I find kneeling is easier. the saw bucks an holders of any kind requires picking stuff up (that's a no go)
I were ear plugs an safety glasses. Just think about what can happen an think. Go easy, cutting is fun. Sharp saw! Never use a dull blade! Good luck with what ever you do.
Army Grunt
   / Do you use a cutting area for Bucked logs? #25
I did not know they existed, so I will check them out. BUt are they really god enough to save you from a saw? David
Absolutly they will stop the chain cold:thumbsup:
Theres a video of how they work somewhere, I'll see if I can find it.
As to the other things, so far, you have been given good advice. How WE cut, depends on the situation.
Sometimes, we will top the tree out (brush it out/cut all the brush off), and then drag the WHOLE tree (less the brush) to an open area and go to town. When you get to the larger stuff, it just depends on what equipment we have. Sometimes we lift it with the FEL, sometimes we cut 3/4 through and use the FEL to roll it over, other times we use the peavy.
Smaller stuff you can use a sawbuck on. But we usually have two of us, and when we get down to that, one runs the saw, and the other holds the peice over another block of wood and keeps feeding the sawer. But we usually dont have much small stuff. Because ALOT of it is already in the air naturally when the tree falls. So we just cut it up that way.
   / Do you use a cutting area for Bucked logs? #27
I can't see the need for a stick and markers to gauge my cuts. :confused:
Once you have your target length... see where it "sits" on your saw with the saw parallel to the log. Gas cap, a letter on the body just a marker of some kind on the saw. Next cut, put your saw at the same point and eyeball where the tip is. Then cut there. I dip the tip til it marks the log sometimes but usually there is an obvious marker on the log already and you just have to pivot the saw.
   / Do you use a cutting area for Bucked logs? #28
Agreed! Unless you are feeding several different size stoves, it doesn't take long to "know" where to make the cut.
Of course, you may be one of those perfectionists, who want a woodpile that looks like the ones in the ads- too nice to use, to burn:D
   / Do you use a cutting area for Bucked logs? #29
First of all, I'm new to running a chainsaw, i've only run 3 or 4 tanks of gas total, and all but 1 were on my Stihl 20" MS290 FarmBoss I bought in May. . .
I need to process my fire wood more efficiently. . .Does anyone use any kind of a platform to cut from? . . .
Good choice for a saw. I love Stihl products. My 024 is probably 25 years old, and it's still a great saw. :thumbsup:
I usually cut the log in place, never used a sawbuck. What you could do is to use several smaller logs on the ground, then lay the bigger logs across them at a perpendicular angle. That would get your cut off the ground, and make it easier to turn with the cant hook.
Here's a great description of the cant hook. Get one. Rural Heritage - Cant Hook or Peavey?
I'll repeat what's already been said: Buy some chaps and steel toe boots. Stihl Protective Wrap-Around Chaps Red Wing Pecos boots
Me too. The saw is already in my hand :thumbsup: If my desired wood length is not longer than the bar, I just have the bar marked with wide tip magic marker. :D
. . . Keeps the saw out of the dirt and is a lot easier on my old back. I'm getting a little long in the tooth to be bending over to cut my logs.
I don't have to bend over when I'm using the 046 Magnum with the 28" bar. ;)
   / Do you use a cutting area for Bucked logs? #30
Mine is a simpler holder that I bought at the local Home Hardware. Here is the link:
Home Hardware - MARKER, WAND HAND HELD SPOTTER 12"
I think they are about $30 in Canada.
I have a 32" piece of broom stick with a mark in the middle that I use to mark off 16" lengths with a quick squirt of the gun. The gun takes the standard contractor's upside down spray cans.
I also carry a lumber crayon and plastic holder in my toolbox in case I forget the spray can. But the crayon does not work well if the bark is damp.
Thanks.
I just use my bar now to measure. The mingo marker in my post looks good. Anybody use it?
Cutting Firewood-Review of Mingo Marker for Measuring. - YouTube
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
401 (A52706)
401 (A52706)
