1974 Ford 2000 will not run
/ 1974 Ford 2000 will not run #1
farminbubba
Ford 2000, Mahindra 485, Massey ferguson special 35
i have a 1975 ford 2000 diesel. its was running fine then one day it sputtered and died. i have changed the fuel filters both inside and outside the tank. Drained the tank, blew out the fuel lines and bled them. Had the injectors checked they were all good. It will start and run for about 15min then sputter and die. You can wait a few hours and it will start and run for about 15 min. While it is running it does sputter a little. anything i can try? i need help!
/ 1974 Ford 2000 will not run #2
If it's a diesel, did you also clean the return liine to the tank?
/ 1974 Ford 2000 will not run #3
Completely remove the bleed screw from the injector pump. Crank the engine over with the starter, fuel shutoff pulled out to the kill position. Does the fuel pump out the bleed screw hole far enough to hit the tire?
/ 1974 Ford 2000 will not run #4
Also, going back to basics, is the vent on the fuel tank cap plugged? An easy way to test this is loosen, or remove the cap and see if the problem still occurs. If the tank can't vent air into it, eventually it will vacuum lock and can't supply fuel to the engine.
Another thing to check is the fuel shutoff valve on the tank, if so equipped. do you get good fuel flow out of the tank?
/ 1974 Ford 2000 will not run #5
Good suggestion on checking the tank vent. The same thing happens when I forget to open the vent on my portable outboard motor tanks. The motor runs fine just long enough to get me out into the current then dies.
/ 1974 Ford 2000 will not run #6
I've always worked under the theory check the easy/inexpensive items first. Then progress up through the more difficult/costly solutions.
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2019 Ford F-550 4x4 Venturo HT40K-X 6,000 lb. Crane Service Truck (A66736)
2019 Ford F-550...
2007 Mack CHN613 (A64911)
2007 Mack CHN613...
2019 VOLVO DUMP TRUCK (A67714)
2019 VOLVO DUMP...
