Snow Plow Options for Deere 2520?
   / Snow Plow Options for Deere 2520? #1
handbrake54
John Deere 2520
Hi all,
So I'm a first time poster...read some threads thus far and decided to post a question. The 2520 is my dads tractor (just bought) and I know he wants a snow plow blade for it, only thing is they are pretty costly new and hard to come by used. So I was looking at some cheap options that may require little/no modifications to make them work with the tractor.
I was scoping out two used options, one is a used Meyer snow plow that I might be able to make a mounting bracket for (don't know if it's too big for the tractor) and the other is a blade off a 317 that I think I could make a bracket for as wee (don't know how it attaches to the 317, but my dad and I can handle a little metal fab and welding):
John Deere 54" Snow Blade
6'6" MEYER FULLY ARTICULATED SNOW PLOW
Thoughts/comments/suggestions?
Thanks,
scott
   / Snow Plow Options for Deere 2520? #3
2 wheel drive/ 4 wheel drive? 2 wheel drive- use chains.
   / Snow Plow Options for Deere 2520? #4
I'm just going to use my rear blade and bucket for my 1/4 mile driveway... Anything will be better than the Cub lawn tractor I had with a 42" blade! I expect my plowing to go from 2-3 1/2 hours to 20-30 minutes with the 6' rear blade...
Its a 4 wheel drive. How much rear ballast if any would I need for the Meyer blade?
   / Snow Plow Options for Deere 2520? #6
You need ballast to offset anything you have on the front end to help get some weight off of the front axle. 500-800lbs should do nicely.
   / Snow Plow Options for Deere 2520? #7
Scott:
Unless you get mountains of snow - go for the 6'6" - as you probably read in some threads the 54" JD plow is expensive and when angled doesn't give that wide of coverage.
I have a 6'6" FEL plow that I modified for my 2320 that works great. We have long drive (800'+) driveway and circular drive in the front of our house. After reading the numerous threads/debates on FEL v. frame mount plows I went with the FEL plow because I need to change between plow/forks/bucket & grapple too much. With a 6'6" FEL plow, KennyD is right that you lose some control on the deep snows (even though I have rear tires loaded & leave my box blade on the back - minus the rippers). To counteract it I have the A frame as far back as it will go & make my first push down the driveway with the blade straight.
If you're doing a frame plow then you should really be fine. The picture of the plow you posted looks in great condition. I lucked out on a used uglier looking one from a neighbor for $200, had it sand blasted, repainted it myself, did the diverter plumbing, welding, new cylinders & other misc. parts. For the plow project I spent about $600ish (not including diverter).
Have fun & welcome!
   / Snow Plow Options for Deere 2520? #10
How about a brand new one for about the same price as the used Meyer. It fits perfectly, no brackets to make, and is even available in JD colors!
Bxpanded
Snowplows
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2014 CATERPILLAR...
