Oil & Fuel B3200 50-hr Service
/ B3200 50-hr Service #1
Signa
Upstate NY
Kubota B3200
First, kudos to poster BP Fick for a great pictorial description of all the service items. If you haven't seen it, I'd recommend it. I wanted to start a new thread to focus specifically on the hydraulic filter changes and some unique issues they present.
On my B3200, the maintenance schedule calls for changing the engine oil, engine oil filter, transmission oil (HST) filter, and hydraulic oil filter after 50 hours. The transmission fluid does not require changing until 400 hours. Now, I do most routine maintenance on my vehicles, but this was my first go-round with a tractor. So the idea of changing filters and not the fluid seemed strange. The service tech at my dealer assured me that it could be done, but that "if I was prepared and quick, I would only lose a little fluid." He said I should have a gal of SUDT on hand for topping off (which I already had). We'll come back to that quote in a bit.
The engine oil/filter were familiar, so I started with them - no problems at all.
Then came the hydraulics. One difference between my machine and BP's is my backhoe -the subframe the BH attaches to makes getting to these filters more difficult. I'll have to post some pictures later, but for now a description will have to do.
I decided to start with the transmission oil filter (HST) on the left because it seemed harder to get to and I wanted to get that done before I got frustrated and tired. On the B3200, there is a hydraulic line directly below the filter and a linkage that appears to go from the clutch to the rear of the transmission traveling directly above the filter. I honestly don't know what this is for as it doesn't seem to move when the clutch pedal is depressed, but it's about 1/4" dia with a turnbuckle for adjustment. Without a subframe, these would be no problem and the filter would come right off. But the subframe lies directly across the end of the filter with only a little room to spare. The only way I could see the filter coming off, especially if I need to be quick about the change, was to remove that linkage. I did so, taking note of how many turns to loosen the turnbuckle so that it could be retightened the same.
That done, I crawled under with my drain pan, lots of rags, the wrench, and the new filter lubed and ready. As I quickly spun the filter off, some oil initially leaked, but by the time I could grab the new one, the leak had slowed to occasional drips. I took the time to wipe around the filter mount to make sure all the dirt was gone and then replaced the new filter. There was hardly anything to wipe up and I bet I lost less than half a pint of fluid. Finally got the linkage back together and went to the other side.
On the right is the hydraulic oil filter, slightly larger than the one on the left. It also has the subframe from the BH as a minor impediment, but there is more space so that the filter can be removed from below after being unscrewed. I again had everything prepared as before and cracked the seal on the filter. Fluid started to leak out, but as I continued to remove the filter, the leak increased. By the time I got the old filter off, it was hemorrhaging hydraulic fluid. Trying to quickly get the new filter on with slick hands, I had visions of my garage floor flooding with oil. The threads finally caught and the filter seated just as the fluid reached the very brim of my drain pan!
Although I had a slight hitch with getting the new filter started on the threads, I think I was as prepared and nearly as fast as I could possibly be. The hydraulic fluid dipstick and filler plug were firmly in place. When it was all done, I had lost nearly 2 gallons (3.8 gal capacity). At this point, I plan to finish the hydraulic fluid drain tomorrow (had to go get more SUDT) and replace the whole lot. It doesn't make sense to me to replace just half the fluid with new.
That was my experience with the B3200. Other tractors are going to vary somewhat, but hopefully this will help some. To echo BP Fick, yes you can do this. But be prepared to replace quite a bit of hydraulic fluid (if not all) after changing the hydraulic filter on the right. The project's a little harder with a subframe, but not impossible. If anyone has a tip on how to do this better, I'd love to hear it. But at this point, I'll be glad to not mess with the hydraulics for a few years!
/ B3200 50-hr Service #2
Signa
Thanks for the write up. Worth reading. You do have me wondering if I have mis-read the service schedule on my tractor. Hmmmm... I was sure it said the hydro suction filter was @ 400 hours, not part of the 50. I'll check that.
I would suspect that if we all knew that loosening the hydraulic suction filter would mean the gushing of fluid, we just would not. We'd just go ahead and drain the fluid properly, being prepared from the beginning, to do so.
Your somewhat painful experience is very valuable to us all. Perhaps we should chip in for a gallon of fluid. :D Cheap tuition.
Seriously, I'll be draining the whole she-bang at 200 hrs or three years whichever comes first and I shall long remember your tutorial here. Thanks for posting it.
/ B3200 50-hr Service #3
Signa- When I had my B3200 I had a similar experience to yours. I also removed and cleaned the metal suction filter. I can't remember exactly how much fluid I lost, but I had to replace roughly a gallon or more. I thought, Gee, I should of just drained and replaced with new.
/ B3200 50-hr Service #5
Signa,
Thanks for posting your experience. I recently traded a B2920tlb for a B3300tlb and received a set of filters with it. I was planning to ask when the time came for somebody's experience with either of these two models with a BH frame. I crawled under it when I got it and noticed the BH frame looked pretty tight for filter changes. So with your detailed description you about convinced me to just drain everything at 50-60 hrs. and replace it all, then replace everything again in the 400-450hr range with exception of engine oil/filter at 200.
Signa, did you also clean the suction/hydraulic screen?
I believe you have to remove a rear tire.
p.s. I just looked at the link provided by bp flick and if I read that right you could change engine and hst filter only at 50hrs (which Signa indicated results in little SUDT oil loss) and wait until 400 hrs. for the hydraulic filter and do complete drain of system at that point. This schedule is slightly different than is what is in my manual. There is also a difference in front axle oil schedule.
Kubota Service Bulletin: Maintenance Intervals | OrangeTractorTalks
Apparently, you COULD have skipped it, according to this bulletin.
Bottom line? What you discovered will benefit us all. Just drain the whole deal if you want to change the hydro-suction filter.
Well, I don't know.... When I compare the service intervals in my manual to the "NEW" service intervals on that link (the X's), they match up with only two exceptions. One is the hydraulic filter, which my manual says to change at 50hr and the NEW bulletin says to wait until 400. The other is that my manual also says to clean the transmission strainer at 50hr, where the NEW bulletin indicates neither that it is due then or that it was changed from that reccomendation. On the other hand, there are plenty of "changes" highlighted in yellow in the NEW bulletin that were never part of the service schedule in my manual....
That link says something about Kubota Canada - I wonder if the service schedules are different. I wish I could find the service bulletins directly from the Kubota website. Just doesn't quite add up.
/ B3200 50-hr Service #7
I don't have a B3200, so dont know for sure on that model, but I used the shop vac trick on my L3400HST. Had the wife put the shop vac on the filler neck opening on the back of the tractor as I changed the hydro and hydraulic filters. I lost less than a quart total for the 2 filters. Another trick is to park parallel to the slope of a steep hill, and change the up hill filter first, then reverse the direction of the tractor and again change the uphill filter. I haven't tried this yet, but it was recommended by a dealer. These are just things you can try next time, the Vacuum thing seemed to work for me. Oh by the way, the engine oil came out much faster when I removed the dip-stick (doh!), by the way on my model and many others there are 2 oil sumps and 2 drain plugs.
James K0UA
James,
After all this happened, your idea of parking sideways on a hill crossed my mind, but I like being near my tools. The shop-vac idea is very interesting, though - I've never seen that before. I'll keep that in mind; though like I said, I'm glad to not have to go through this again for a while.
I'm going to look at that tomorrow when I finish draining the fluid. The manual doesn't mention needing to remove the tire. My tires are loaded and awfully heavy (I think it's about 200# ballast each, plus the dry weight of the tire/rim). If the tire really needs to come off to clean the strainer, I'm not sure that's a job for me alone.
/ B3200 50-hr Service #10
I can't remember what the 3200 has for a vent but I did my filters on the l5740 today and all I did was pinch the vent tube with a pair of pliers and then went to it. I maybe lost 1/2 liter over what was in the filters. Very pleased with the light loss of fluid.:D
I'm not aware of a vent tube on the B3200. Where is it located on yours?
/ B3200 50-hr Service #12
I can't remember and will look in the morning but on my l5740 the vent tube is part of the filler cap on the back end.
/ B3200 50-hr Service #13
Signa
Kubota is moving toward extended service intervals, that much is for certain. Printed manuals get out of date quickly and they are super-ceded by newer Kubota information, that much is also true.
Kubota used to recommend an extensive 50 hour service, and that is likely reflected in your manual. Approximately a year ago, Kubota released a "new" 50 hour recommendation for most of these units, that pushes back the front axle change, no longer recommends changing the trans/hydro fluid and full hydro fluid dump, and merely swapping out the trans filter.
The discussion here on TBN has been endless between those who agree or disagree with Kubota's newer recommendations concerning service intervals.
I just recommend common sense.
/ B3200 50-hr Service #14
Signa
BP: Looks like you think like me. Everything was about a year ago. When I think back to which tractor I owned when it was the everything at 50 and then count back to the ones where it changed in the manual not having to change the hyd at 50 it's closer to 2 to 3 years ago. I do believe they phased in BXs first then I know they did the Bs. Not sure on the ones bigger than those.
Being the kind of person that fights being stuck in the 60s but wanting to stay up with the changes that go on in the world I sought answers from the Company vs those that never change from the way their grandfather always done things or does things a certain way but don't know why, they just do. I contacted the Kubota Co. I have kept the email from Kubotas hired Representative, be he sales or Molecular Engineer or the guy walking by the Computer the day I enquired or technician or just PR person. His remark that people(s) on TBN don't know what they are talking about was in reference to the not following the owners manual that came with their Kubota at recommended change schedules.:) Some individuals were saying the manual had been misprinted and the not change the Hyd Fluid at 50 was a mistake. I've thought about editing that out of the email but no, I'll just send it word for word as it was sent it to me.
John, the person or persons from TBN do not know what they are talking
about. There has not been a Service Bulletin or even a notice sent to the
dealers that this is a mistake in the Operators manual. Kubota Tractor
recommends for you to follow your Operators manuals for servicing of each
unit you have. The BX2660 and the BX25 do not have to have the transmission
fluid change until it reaches the 400 hour mark. For the F2680, it is the
200 hour mark. The transmission oil filters need to be replaced and the
suction strainers cleaned at or before the 50 hour mark for all three
units. Your selling dealer can also assist you if you have any questions in
regard to servicing your tractors. Thank you for purchasing and contacting
Kubota Tractor Corp.. DATED 2-12-2010
/ B3200 50-hr Service #15
Just a though on changing the up hill side first, If you have a back hoe, you can use the out riggers to make which ever side you want to be up hill, then put a jack stand under it....
/ B3200 50-hr Service #16
Here is a perfect example of why one should be careful of what they say here on TBN. It can come back and bite you on the butt some times.:laughing:
Looks like Troy has some free time and is cruising the 2 year old threads or he's searching info on his new (or nearly new) B3200.:thumbsup:
Troy, When are you coming back to visit?:)
/ B3200 50-hr Service #17
Hey John, I actually in KY now, just up in Ashland, and will be roaming around WV for the weekend, spending money on my other hobby, model trains... And I should have no problem working on my tractor if I ever get back home, looks like it will be after Thanksgiving before I allowed back in to Louisiana now.
/ B3200 50-hr Service #18
Come see me if you get close. 606-687-0008
/ B3200 50-hr Service #19
On the B3200, there is a hydraulic line directly below the filter and a linkage that appears to go from the clutch to the rear of the transmission traveling directly above the filter. I honestly don't know what this is for as it doesn't seem to move when the clutch pedal is depressed,........
I know this is an old thread, but those just finding this info searching for 50 hour service guidance may find this helpful.
I just did the 50 hour service on my B3200. The linkage referred to by the OP is the left side brake linkage. It is actuated of course by the left brake pedal via a rod and lever that shares the clutch pedal mechanism, making it appear to have something to do with the clutch. This is the rod, along with its mate on the RH side, that you will adjust to set brake pedal play.
On the right is the hydraulic oil filter,.............
According to my manual only the HST filter needs replacing on the 50Hr. The RH side filter, the Suction Filter, does not get replaced until 400 hours with the draining and refilling of the fluid. I personally will be doing both filters and the fluid at around 200 hours and then again at the 400, and from thereafter most likely at 400 hours. This is of course a matter of personal choice, which for me is going to be based on calendar as well as meter time.
For those hesitant to do their own service I say "Just Do It"! It's easier than changing oil and filter on the average car just because everything is so much easier to get too.
/ B3200 50-hr Service #20
Anyone have a list of what's needs filter/oil wise?
