Questions on re-grading the perimeter of my home
   / Questions on re-grading the perimeter of my home #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
With all the rain and storms the east coast has been receiving, I need to add more slope to some areas around the exterior of my home. My question is, can I just add dirt and tamp it to the slope I want or do I need to remove dirt and start with a "clean base" before adding dirt?
   / Questions on re-grading the perimeter of my home #2
Depends upon the grade at the house, if it will make it less than an inch or so below the slab I wouldn't do it; lower the dirt level instead.
My home has a full walkout basement, so the slab is a ways down. I'm thinking about building it up where needed and sloping it from there. Just wondering if water will just seep through the new dirt down to the original and continue to seep towards the house.
   / Questions on re-grading the perimeter of my home #4
If there is no existing lawn you can compact new soil over the old by wheel rolling it. If you do have an existing lawn, shave off the sod a bucket / blade width at the bottom of the slope and start filling and compacting over the remainder of the slope. For small areas, or areas less than the width of a bucket, a couple of shovel widths of soil to soil contact at the bottom of the slope should be fine. Be sure to keep the soil height at least 1" below the weep screed (on stucco houses), siding, or brick ledge.
I'm assuming that you can get your tractor to the area. If not, hand tamping for compaction will suffice.
LG 60" PIN ON WHEEL LOADER FORKS (A51242)
LG 60" PIN ON...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
