NEW D170 MODEL COMMENTS ???????
/ NEW D170 MODEL COMMENTS ??????? #1
doxford jim
British Columbia, Canada
1959 MF-65 sold, 2007 Jinma 554 diesel.
Hi Guys,
I have just bought a D170 mower and was wondering what comments other owners might have on their machines.
I know, it is a bit late asking for opinions now, but the deal was pretty good and it was the last one in the store, so I bought now and worry later !
My old trusty Sears rider mower has been loaded with problems that I keep fixing (42" deck, 15.5 hp Kohler engine ). Finally decided that a new mower was needed. My grassy area is 3.0 acres or more and the old one got really worn out.
I have used the D170 the one time and found it great. What took me 7 hours to do with the old mower, I did easily in 3.5 hours with the D170 - with much better results too. The only con so far is the fuel consumption - but more HP = more fuel.
How have you owners found your machines ? Any particular problems to worry about ? I have found that the grass cutting height lever has a habit of getting in the way when getting on or off the mower !
So far, my impressions of this machine are positive, but then I only have 3.5 hours use.
Any info you could share with me would be greatly appreciated.
Thanks
Jim
/ NEW D170 MODEL COMMENTS ??????? #3
I certainly don't have long-term data to support my theory, but if the D1xx series continues the problems associated with the LA1xx series (both 100 series Deeres) then you can expect your mower deck to have the highest maintenance requirement. Keep good fresh fuel treated with Seafoam or equivalent and the engine will probably perform quite well for many years.
Expect to do regular maintenance by greasing your deck spindles every 10 hours of use or less and be ready to replace idler pulleys that may start howling. I sharpen my blades once and then replace them the next time they need service because the metal has worn so thin on the lift blade portion that it is paper thin. If you have the electric PTO clutch, it puts a tremendous shock load on the deck when energized.
Any odd sound I hear from the deck, I troubleshoot right away. I won't let an idler fail or a spindle either. I had one spindle fail (break) and it was making noise. If I can't stop the noise with grease, I replace the spindle. The whole spindle is less than $60 US. Idlers are $9-$12 each. I also keep spare blades. These maintenance items are so common on these decks that kits of parts are sold by 3rd party vendors on eBay. Just keep an eye on things and you can probably manage it if you do your own maintenance. If you have to have it worked on by someone else, the deck problems could be costly. Time will tell. . . .
I have removed the plastic covers from my Edge Cutting System deck so I can easily get to the spindles zerks for greasing. Recently when I stopped mowing, I felt of the top of the pulley on a spindle and it was so hot I could not hold my hand on it. That's probably normal, but just demonstrates that heat from friction is being generated and good EP grease is needed. Don't buy the cheap grease. Look for NGLI-2 grease or better.
/ NEW D170 MODEL COMMENTS ??????? #4
I may sound like I'm trying to burst your bubble, but ain't no way I would mow 3 plus acres with a big box store mower.
But hey, that is just me.
/ NEW D170 MODEL COMMENTS ??????? #5
If you have a leaf blower use it or compresed air to clean off the top of the feck, Use a water hose sparingly to clean it on top. I have an older L130 with all original belt, idlers and spindles.
I learned this next lesson rather quickly, plan to use the electric pto sparingly and slow down to an idle to engage it. When I first got this mower I used the switch frequently it lasted to about 75 hours and was toast. The replacement has gone another 200 hours with no problems.
Last, don't overwork the transmission, it will last alot longer if you can avoid steep grades and pulling heavy carts.
/ NEW D170 MODEL COMMENTS ??????? #6
I have an L130 like Steve's, and my opinion is don't expect any Big Box Mower regardless of brand to be built to the same quality standards as a Lawn & Garden tractor like Steve's X749, or a SCUT/CUT.
Jinman is right about the mower deck and electric PTO being the most maintenance intensive items on BBM grade units. That's been my experience too.
/ NEW D170 MODEL COMMENTS ??????? #7
I have a 2008 LA150 which about the same quality/class of machine.
Everything Jinman said about maintanence on the deck is all good advice. I only greased my 54" deck about twice a season, and I now have a rough sounding spindle bearing after 150 hours. Everything else is good, but definately needs blades.
Reduce RPM before engaging PTO. Try to find the least amount of RPM you can engage PTO without killing the engine. I didn't know about this when I first got my tractor, but a neighbor set me straight.
Hydrostatic Trans. Pretty sure that is what you have, if you can change the oil to synthetic that would help (may void warranty, not sure, check into it).
Sure everyone wants an X5 - X7 series ($6k - $12K). But if you are willing to do a little more maintenance, give-up some performance and, hydraulics, you can get by for a whole lot less.
Good luck!
/ NEW D170 MODEL COMMENTS ??????? #8
Good luck!
I think there are plenty of people who want nothing more than the X3xx ($3k to $5.5k) series for mowing and towing. The X5xx and X7xx series have locking differentials and 4wd. Since you purchased a snowplow for your D150, I think you are gonna find out how well it works with only one rear wheel turning on the ice this winter.
/ NEW D170 MODEL COMMENTS ??????? #9
I don't understand what he said that made you angry. I really don't. I may be dense, but please explain what you think he said. Jinman has a reputation of being very knowledgeable and helpful on this board.
James K0UA
/ NEW D170 MODEL COMMENTS ??????? #10
The only error that I have caught so far is Jinman mentioned the D150 and If I recall Piratesignal has an LA 150. A MiNOR ERROR IMO.
Jinman is a very helpful poster here Piratesignal you could learn alot by reading his posts.
Jim was just stating that he is hopeful that the new John Deere D series is better then the LA series they replaced. If it isn't much different other then the name he made mention of some areas the op of this thread should look into. If the D150 and LA150 are basically the same tractor other then a few tweaks then I don't see where that is such a terrible offense.
/ NEW D170 MODEL COMMENTS ??????? #11
I said error not offense, there is a difference. I mentioned this because of the reference to this being a John Deere forum.
Jinman was referring to Piratesignal's current thread about installing an actuator on the front of his LA150.
I know, I said offense in regards to how Piratesignal responded so harshly. I don't see what Jim said that could be so offensive to anyone let alone Piratesignal.
/ NEW D170 MODEL COMMENTS ??????? #13
Piratesignal, I don't have anything against you or your LA150. Honestly! I think you misread my post completely, at least my intent was hidden. I did make a mistake and call your mower a D150 because that is the newer model designation of the same mower you have, and your mower looks spotless and new when I see pictures of it. I was suggesting that these LAxxx or Dxxx mowers (100 series) are built for mowing and to compete with other low-cost brands. I also own a LA145 with 130 hours and I have a whole history of posts about that mower with what I think are good points and bad points.
Anyhow, I didn't mean to embarrass, bash, or say anything off-the-wall about your tractor. I did feel that you made a bit of an inaccurate statement with you mentioned that everyone wants a X5 or X7 series tractor. I think there are plenty of people who would love to have an X3 series. All of these are in JD's "Select Series" tractors. Ours are not.
You could make a valid argument that my comment about your snow plow on your LA150 did not belong in this thread. That's at least partially true, but also related to the fact that the X5 and X7 can have differential lock and 4wd in the X7 model. Those are the features many owners like along with power steering. All of those things are not available to us on our tractors at any price.:(
Piratesignal, I truly did not mean to offend you. I will try to be very careful and double check all my posts relating to you and your equipment in the future. I want to help and give good advice. Irritating you or making you angry is not something I would ever do on purpose.:drink:
Hi Guys,
Thanks for your replies - they are exactly the sort of information I was looking for. I haven't responded till now as I have been busy on other things.
Re area mowed - I am guessing the area but it is pretty large. I have mowed it with the 15.5 hp Sears mower for six years. Of course that little rider has worn out during the process. The previous owner of my place used it as well, so it has had a lot of use.The area is about four or five times that shown in the attached foto below.
The D170 has easily cut the mowing time in half - from seven hours down to three and half, and it relive comfort too.
The info on the eletric clutch and transmission is very helpful - I wasn't aware of any problems. Having only used the smaller Sears mower, I have had little experience on other machines and the D170 seemed to be perfect for my needs.
I guess, like everything else, it depends on use and care for a long life.
Any other bits of information you guys could send my way, would be greatly appreciated.
Thank you
Jim
/ NEW D170 MODEL COMMENTS ??????? #15
Jim,
My apologies for the interruption in your thread:eek: and Welcome to TBN.
Your lawn looks great and the new D170 will work well for you as long as you don't strain it. That is what your tractor is for anyway.:thumbsup:
/ NEW D170 MODEL COMMENTS ??????? #16
dox-ford Jim,
If I had found these tractor forums before I bought my JD LA120, I would never have purchased it. And that would have been a shame. I am coming to the end of my 5th year with my tractor. It has worked flawlessly. (Other than a valve adjustment when new)
After reading the bad things about the "Box Store" tractors, I ran out to my garage and expected to see the transmission on the floor and the blades ceased and sticking through the deck. It never happened. I turn the key, it starts, I engage the blades, they turn. I step on the gas, it goes (It even backs up)
So many happy hours of seat time to you.
/ NEW D170 MODEL COMMENTS ??????? #17
...first time posting....not wanting to hijack the thread, but as the owner of a Scott's 2048 with a recently blown Kohler motor, I too was interested in D170 insights
/ NEW D170 MODEL COMMENTS ??????? #18
Hi Guys,
Thanks
Jim
I find it to be great, isnt great on gas but is better than my cudb cadet. The only problem I have is having to remove the pulley covers to adequately clean out all the clippings. Good purchase:)
/ NEW D170 MODEL COMMENTS ??????? #19
for what it's worth, the D170 has an 11ga deck (thickest of all D-Seies) and the trans is the K-46 which is the same as the higher-cost x-300.
/ NEW D170 MODEL COMMENTS ??????? #20
Hi Guys,
Thank you
Jim
Looks like you're doing just fine. We had a LA130 for 3 years which was similar to your D170 but had a 48" deck. It never missed a beat, never spit nor sputtered, unlike our X720. Our property is pretty rough and my wife likes to mow around the farm sheds and road between the fields and she wanted something a bit heavier and power steering. We had a JD 425 before the LA130 and it smashed the wiring harness between the mower deck gearbox and the frame, luckily it was still under warranty. Then the power steering cylinder came apart internally, out of warranty, a new one was like $375. I had it cut apart on a lathe and put the proper amount of Loctite on the nut that holds the piston on the cylinder rod and had it welded back together and all was well. So the Premiums are definitely not perfect. Our X720 has already been back in for fuel related problems.
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188002 (A61165)
INOP/NON-RUNNING...
2013 FORD F250 (A60460)
2013 FORD F250...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
New/Unused CFG Industrial QH12R Mini Excavator (A61166)
New/Unused CFG...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
