Laying water line across pasture
   / Laying water line across pasture #1
tessiers
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I was laying some water line across my pasture to reach another area when my fater came up with a great idea. We put on the single bottom plow and cut a single furrow 10" deep and layed the sod right beside the hole. Layed in the water pipe and with a garden rake layed the sod right back in place just a purty as you will. Drove over the trench a couple of times and you can hardley tell we were there. Just passing along an Idea that worked for us.
   / Laying water line across pasture #2
In central Maine that sounds like a summer only water line at 10" deep.
   / Laying water line across pasture #3
Idid that last summer with 300' of Cat5 cable. I agree it did work like a charm.:D
   / Laying water line across pasture #4
Just did the same thing but my line just gravity feeds the pasture water troughs and I drain for winter. (I think our frost line here's over 36 inches and the old one bottom ain't goin' that deep)
In maine pasture is a summertime only thing, unless you plow paths for your animals that is. I tap maple trees and routinely have taps 7 or 8' high that were 3 or 4' high before the thaw. People always comment on the 3-4' high stumps and think its a waste leaving that wood behind, what they don't know is it was cut with the surface of the snow. I just disconnect in fall and blow a little air through the lines, no problems since I switched to Pex tubing instead of black plastic.
   / Laying water line across pasture #6
That method also works great for installing silt fence around a construction site.
   / Laying water line across pasture #7
I have dug 3 different trenches (and soon planning on another one) for water lines, using my middle buster. With alittle weight on it (someone standing on it) it works perfect.
Travis R
   / Laying water line across pasture #8
I am on my way to do about 2000 feet of waterline with my middle buster, will let yall know what I learn
   / Laying water line across pasture #10
Here is what we use - a sub soiler with 2 inch PVC attached.......
2016 Chevrolet Cruze (A50324)
2016 Chevrolet...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2002 Sterling Bucket Truck (A50323)
2002 Sterling...
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 24"...
UNUSED AGT TIRE CHANGER (A51244)
UNUSED AGT TIRE...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
