Laying water line across pasture
   / Laying water line across pasture #1
tessiers
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I was laying some water line across my pasture to reach another area when my fater came up with a great idea. We put on the single bottom plow and cut a single furrow 10" deep and layed the sod right beside the hole. Layed in the water pipe and with a garden rake layed the sod right back in place just a purty as you will. Drove over the trench a couple of times and you can hardley tell we were there. Just passing along an Idea that worked for us.
   / Laying water line across pasture #2
In central Maine that sounds like a summer only water line at 10" deep.
   / Laying water line across pasture #3
Idid that last summer with 300' of Cat5 cable. I agree it did work like a charm.:D
   / Laying water line across pasture #4
Just did the same thing but my line just gravity feeds the pasture water troughs and I drain for winter. (I think our frost line here's over 36 inches and the old one bottom ain't goin' that deep)
In maine pasture is a summertime only thing, unless you plow paths for your animals that is. I tap maple trees and routinely have taps 7 or 8' high that were 3 or 4' high before the thaw. People always comment on the 3-4' high stumps and think its a waste leaving that wood behind, what they don't know is it was cut with the surface of the snow. I just disconnect in fall and blow a little air through the lines, no problems since I switched to Pex tubing instead of black plastic.
   / Laying water line across pasture #6
That method also works great for installing silt fence around a construction site.
   / Laying water line across pasture #7
I have dug 3 different trenches (and soon planning on another one) for water lines, using my middle buster. With alittle weight on it (someone standing on it) it works perfect.
Travis R
   / Laying water line across pasture #8
I am on my way to do about 2000 feet of waterline with my middle buster, will let yall know what I learn
   / Laying water line across pasture #10
Here is what we use - a sub soiler with 2 inch PVC attached.......
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
UNUSED X-STAR SKID STEER QUICK ATTACH LAND LEVELER (A51243)
UNUSED X-STAR SKID...
John Deere 920 Platform (A50514)
John Deere 920...
