Filler / Plug / Dipstick location
   / Filler / Plug / Dipstick location #1
SandburRanch
NHtd75
The loader arms/ brackets etc. being in the way doesn't help one bit but could someone tell me where to find the hydraulic oil filler / plug / dipstick location on a TD75D. Left side , right side, rear, most anything would help. The pics are from the operators manual and the best I can do from them is #1 may be a hex head.
   / Filler / Plug / Dipstick location #2
The filler plug/dip stick is at the rear on the right hand side above the pto guard. IIRC, it takes a 13mm wrench. It has a metal gasket underneath the bolt head.
If this still isn't specific enough, I'll take a picture of our TD95D and post that.
let me know.
   / Filler / Plug / Dipstick location #3
Here's a picture. The hex bolt head between the coupler covers and in front of my knife is what you are looking for.
Thanks a bunch Jerry/MT. After your first reply I went back to where the tractor was and with a little eye strain I saw it. If my tractor was as clean as yours it would have been more visible. But there seems to be a problem. What was once a hex head is now what I would call a Gawdzillaoid. It isn't any wonder it didn't match what the manual showed. I don't know what monkey has been on that with what kind of wrench but I can say for sure it was the wrong one. It looks as if I'm stuck with using a pipe wrench now but I've been there before.
Thanks again, SandburRanch
   / Filler / Plug / Dipstick location #5
That's probabaly a $25 hex head ! Glad you found it.
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
