Critical Compoment failure : Horn won't sound!
   / Critical Compoment failure : Horn won't sound! #1
Zxyrthe
Ashland, VA
Kioti CK20 HST
I'm not sure what I did. Maybe I jostled something loose but my horn has quit working. I count on it regularly to startle my wife and make a general ***** of myself with.
All the other electrical components work and it shares a fuse with other working functions.
Any idea where the horn's actually located? Maybe I tore it off. Better yet, maybe I should upgrade to some kind of air horn!
Thanks all.
   / Critical Compoment failure : Horn won't sound! #3
dangit... mine doesn't even have a horn to break!!!...
I passed a saltwater hauler the other day on Interstate and noticed that he had a set of 3 train horns mounted just behind the cab, aimed directly out the driver side.... Just thought to myself, I would HATE to be on a motorcycle beside him when he let those things go...
   / Critical Compoment failure : Horn won't sound! #4
Yeah, I am bummed out because my horn quit working too. The horn on the CK20 is in front of the radiator. I cannot see anything obvious on the horn itself so I need to trace things back to see if it is a bad ground or if I tore a wire off.
I ran over a piece of 1/4 in. rebar a week ago that I was using as a grade stake, thought it was a piece of brush, maybe that is the culprit.
Also tore off the light I had installed on the roll bar backing into the garage to get out of the rain.
I need to be more careful with my toys---little things are an aggravation.
Thanks for the info, Gil. Sorry to hear about the damage. I too am my own worst enemy.
PoorMan - it looks like a reasonable mod. Anything from a bicycle horn to a train horn would be better than nothing.
   / Critical Compoment failure : Horn won't sound! #6
I wish I had a horn. :) Is the horn button/switch in the center of the steering wheel or is there something else used?
   / Critical Compoment failure : Horn won't sound! #7
My Kioti Dk45 came with a horn right out of a 1960 VW beetle. It was embarrassing to use that thing. I went to NAPA and bought a real horn...not an air horn (hay...an air horn...cool idea). At least im not embarrassed to toot it.
   / Critical Compoment failure : Horn won't sound! #9
I'll be Capt. Obvious. Have you checked to see if you horn has a solid ground? If that doesn't work, you can always use the bumper sticker, "horn is broke, watch for middle finger." Sorry Just trying to make gold tonight :laughing:
@Egon - I actually have one of those but the bulb has dryrotted away.
@Beltzington - The ground is there and everything looks like it's intact. It could simply be a bad switch. If I have time today, I'll try to see if I can bypass the switch and test it.
Thanks all.
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
2025 Yakta YXR610 Zero Turn Lawnmower (A57453)
2025 Yakta YXR610...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
1R CULTIVATOR, 3PT (A58374)
1R CULTIVATOR, 3PT...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
