Mowing Cotter pin fell out on Bush Hog while mowing
   / Cotter pin fell out on Bush Hog while mowing #11
My equipment came with the loop style spring clips everyone is showing. I lost three the first day using the mower. I figured that was just the cost of mowing high brush and went out and bought a big box of them at HF. Strangely, I have not lost a single one since then.
I guess the spring tension was the deciding factor, but I did not think about them being different at the time.
We buy them individually and check the tension then. We buy ours at a local hardware store and have yet to run across a weak one. We haven't had to buy any in quite some time.
   / Cotter pin fell out on Bush Hog while mowing #12
One of the lower three point hitch attachments I discovered the cotter pin had fallen out as I was backing under a fruit tree. I quickly shut everything down.
I got down, and managed to get the pin back in (with out the cotter pin) and I raised the bush hog and parked the tractor.
Does this happen often? Is there anything I can do to prevent it?
Clearly, I'm not going to use it again until I buy some spare cotter pins.
Any advice is appreciated.
Thanks,
David
Cotter pin? That's the 1st time I've heard of using those on the lower 3pt arms. Get a bunch of lynch pins at Tractor Supply. That'll solve your problem.
   / Cotter pin fell out on Bush Hog while mowing #13
I use this type and have never lost any.
I lost one of those in the woods last year. I ran over a clump of small saplings and they snagged the lynch pin and pulled it out. I keep a couple of spares in the tractor's tool box but I have not lost any since last year.
Flusher,
You are right. Cotter pins are the split pins you bend in opposite directions after inserting them through. Like for a wheel bering job.
I meant those spring pins that are NOT Lynch pins, but are the other style like on my reciever hitch pin. Unfortunately I do not know the correct name. :ashamed:
Silly computer guy needs to get up to speed on the tractor lingo...
I made something out of an old shirt hanger and a pair of pliers. It looks wimpy and lame, but I suspect it will keep the pin in place until I go get lynch pins tomorrow.:thumbsup:
Thanks guys.
I can't tell you how relieved I am that I caught it and did not break anything like I could have.
PS - I'm loving my tractor, and my grapple, and my bush-hog. AWESOME tools. the property is already looking better and I've only got like 5-6 hours seat time so far.
Be Well!
David
   / Cotter pin fell out on Bush Hog while mowing #15
we call em hairpins
soundguy
we call em hairpins
soundguy
:laughing::laughing::laughing: No flipping way!:laughing::laughing:
You just sent me to the torpedo room for water slugs like a noob!
That is funny though!
Now, seriously, what are they really called?
David
   / Cotter pin fell out on Bush Hog while mowing #18
  • Pivot Point fasteners, clevis pins, cotter pins, quick release devices, cable assemblies, specia.pdf
2015 Silverado 1500 (A50323)
2015 Silverado...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A51244)
UNUSED FUTURE MINI...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52128)
2012 Freightliner...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
