Shaver HD10 not lifting pounder head
/ Shaver HD10 not lifting pounder head #1
wfd2
Member
Michigan
IH 656 Diesel
I bought a used Shaver HD-10 post driver for the back of my '73 International 656D. The Shaver isn't too old as far as farm equipment goes, it's a 1998.
I hooked it up on the 3pt hitch, plumbed the 1 1/4" return line back to the tractor's resevoir and plugged it into a good rear remote. (I have dual remotes on the back of this tractor and both work, tested by my 2000 loader.)
Now, drum roll.. try to lift pounder head... and music stops. Nothing. The cylinder will not move the head up. But, the cylinder will not allow the head to fall, unless I push the valve to allow it to drop. So, in my mind the seals in the cylinder are good or else it wouldn't hold the pounder head in the air. I also tested the drop cycle and everything seems to move freely. The cylinder will even stop the head mid way down the fall. When I dump the valve, oil does shoot out the return line back into the sump, so oil is making it into the cylinder but obviously not enough oil or pressure.
Does anyone have any experience with this pounder? It doesn't seem as though it's the tractor... it's a pretty big tractor for this pounder. I believe the pump is rated at 15 GPM w/dual remotes. Also, the lines are "stock" Shaver, so I don't think anyone put a smaller high pressure line on it, but again I could be wrong.
Does anyone have any ideas? Your experience and insight is appreciated as this Saturday is in the books, score being Shaver 1, Bill 0.
Thanks!
Bill
/ Shaver HD10 not lifting pounder head #2
It doesn't matter how 'big' the tractor is, or how many GPM it is rated for; pressure lifts the head. Put a 3000 PSI gauge in the remote coupler and stroke the valve, I'll bet the relief pressure is down around 1200-1500PSI. Those IH's have wimpy low RV settings. I have seen 656's that wouldn't operate a Kuhn rake, and 686's and Hydro 70's that wouldn't open a round baler gate properly. A higher rated RV is available from CaseIH.
That Shaver driver has a very small cylinder I.D and requires decent pressure to lift the head.
/ Shaver HD10 not lifting pounder head #3
wfd2,
You said this.
[ The cylinder will not move the head up. But, the cylinder will not allow the head to fall.
Then you said the fluid rushes out. ]
So is the Shaver pounder weight being lifted up, or is it up, but won't fall?
So, is the cyl extending and retracting, or is some other mechanical thing not letting the weight rise
and fall.
Like RickB said, put a pressure gage in the circuit to verify pressure.
Have you looked at a parts diagram to see how the machine is supposed to work?
/ Shaver HD10 not lifting pounder head #4
Thanks!
Bill
I bet it was last used on a JD tractor and has the wrong valve setup ie open center, closed center. Check the history of the drivers use? Ken Sweet
/ Shaver HD10 not lifting pounder head #5
I am thinking that if the valve was setup for closed center, the the remote valve PRV would be going off, because you are blocking total pump flow.
If you think it is closed center, remove the closed center plug. Item #7 Check with the manufacturer or determine what plug is in the valve.
Parts manual.
HD-10 Post Driver
Go to page 50 , shows the valve and the open center plug and the closed center valve.
However there is a lot of set up for the Shaver, and if not done correctly, might not work as advertised.
http://www.shavermfg.com/downloads/HD12FinalWebSite.pdf
/ Shaver HD10 not lifting pounder head #6
Closed Center Plug is an important thing to check (for other reasons), but if sufficient pressure and flow was available at the driver's operating valve, the head would go up when the valve is stroked.
J.J.,
So if I am understanding you correctly, if the pounder is setup for an open center using a fixed displacement pump, and the 656 has a variable volume pump, then the oil is just passing the cyclinder and ending back into the sump without lifting the cylinder?
So, is this correct below?:
-Open Center is for fixed displacement pump (without open center, the pump continues to pump, up to dangerous pressure, engine stall or pump failure)
-Closed center if for a variable volume pump (without closed center, max pressure to raise head is never reached and pump stops pumping)
Am I close? I'm just learning about this tonight, but is starting to make more sense.
I searched the forums and internet and I'm not sure which configuration I need. I will try to call Shaver tomorrow.
Does anyone know what type of pump the 656 has? Fixed displacement or variable volume pump?
/ Shaver HD10 not lifting pounder head #8
J.J.,
Your IH will have an open center hydraulic system, therefore a fixed displacement pump. Make sure the driver is setup for open center for starters. Also just FYI, the shaver post drivers use a displacement type cylinder, so there are no internal seals. Only seals on it are the seal around the shaft.
/ Shaver HD10 not lifting pounder head #9
It would be best if you called the manufacturer and ask some questions about the kind of valve you are using whether it is setup as open center or closed center.
Thanks for all of your information and sharing your experience. I will let you know the outcome as I don't think the pounder is setup for open center. My Test: When tractor is running, oil should be bypassing back to sump at a fairly rapid flow. It's not.
/ Shaver HD10 not lifting pounder head #11
As I said before, call the manufacturer and they will tell you how to identify whether it is open center or closed center.
Whenever you are messing with the post pounder, does the tractor PRV ever activate?
Where is the hyd supply for the pounder coming from? From the FEL PB, or a remote valve?
Where is the return from the post pounder going to?
Does the post pounder valve have PB?
On page 50 of the owners manual, they show a supply hose G-17 as the supply hose, and G-20 as the return hose.
There is a hex plug beside the return port.
They should have used the supply to the pounder valve and the PB out to the 3pt, and a cyl return hose to the tank. Not sure what is under the hex plug.
Does the hyd valve have a brand name and model # on it ?
/ Shaver HD10 not lifting pounder head #13
A pretty good indication that a closed center plug is installed in the driver's valve. Given a proper supply of oil from the tractor's remote valve through the couplers to the Shaver valve.
/ Shaver HD10 not lifting pounder head #14
If you are thinking this valve used as a closed center valve, there will be no flow in the out port until the cyl is stroked, as the pressure just waits at the valve for the lever to direct the fluid to the cyl.
So in a closed center circuit, there will be no flow through the return port except when the fluid is pushed out by the stroke of the cyl.
Here is a basic closed center circuit.
http://www.princehyd.com/LinkClick.aspx?link=techFAQ/ClosedCenterDA.pdf
I would open the hex plug and see if the hex screw is screw in.
What I think will happen if a closed center valve is used in an open center hyd system is this. In neutral, the flow is blocked, so the relief would activate as soon as the pump is running. The pressure should jump up to the FEL valve PRV and start screaming.
A hyd gage would check all this out.
I did call manufacturer. Standard configuration is open center valve, however, they also make it in the closed configuration. I'm not sure how to physically determine which configuration I have besides some of the very basic tests I already performed.
I'm not sure if the PRV (pressure relief valve, right?) is activating. I'm not sure how to check as I'm fairly new in diagnosing hydraulics.
The presssure line is connected to a quick coupler in the back of the 656. The remotes were tested using my 2000 IH loader and they work fine.
The return line is plumbed and goes directly back to the sump, where the dipstick is put into the tank.
I'm not sure if the valve has a PB as I'm not sure what "PB" stands for.
The valve is a Gresen. I will check on the model number tomorrow.
I truly appreciate the help and knowledge you are sharing with me JJ.
Thanks so much for your help
/ Shaver HD10 not lifting pounder head #17
What is supplying hyd to your 3pt.
I was going to ask you the color of your valve, as the Prince is black and the Gresen is red. Do you have the 3 lever valve?
PB is power beyond, and is used with open center valves.
Some hyd valves come as open center with or without PB, where the fluid is flowing all the time the tractor is running. Some of the valves can be converted to closed center, and the closed center valves are used mostly with variable speed valves. Basically, the fluid just sits there waiting to be used.
The valve you have is convertible, and they will ask you how it is configured. I am guessing the screw is in the port under the hex lug. I believe blocking that port make it a closed center valve
If that valve were to be used as an open center valve, the screw would be screwed in to separate the OUT flow from the hyd fluid to the next valve. The return port would go to tank, and the PB out would go to the next valve, which should be the 3pt.
The tractor is supplying hyd to the remotes on the back of the 656. I then have the Gresen valve plugged into the remote. Then the valve goes to the cylinder in the pounder. (Return goes back to the sump on the tractor.) I'm not sure if that answered your question or not.
The valve is red, which should be the Gresen valve. It has one lever on it. I will post some pictures tomorrow after I take them in the sunlight.
So to convert this valve from closed center to open center, I'd just have to remove a screw? Or do I need to order a new part?
Look for pictures tomorrow JJ. As always, thanks!
Bill
/ Shaver HD10 not lifting pounder head #19
Bill
To convert from closed center to open, remove a long plug and install a short one. The HD-10 operator's manual is linked here:
http://www.shavermfg.com/downloads/HD-10-operator-manual.pdf
The single spool valve is on page 50. Remove the proper plug and tell us how long it is. The open center plug will be flat at the base of about 1/2-3/4" of threads. The closed center plug will have a longer tit on the end opposite the hex. Alternatively, Blow air into the supply hose with the control lever in neutral. If air comes out the return hose, the valve is set up for open center hydraulics.
/ Shaver HD10 not lifting pounder head #20
wfd2,
You say you are running the return from the Gresen valve to the sump. How does the fluid get to the sump? Through the remote valve, or directly from the Gresen valve to the sump.
Do you have the hyd supply and return line plugged into the remote?
