BX front axle pivot zerk
/ BX front axle pivot zerk #1
Rfisher7381
South West Michigan
Kubota BX2360
Is there a grease fitting for the front axle (BX2360)? Seems like there should be but I can't seem to find it. Thanks
/ BX front axle pivot zerk #3
On a side note, check the torque on the castle nut on the pivot. I don't remember the torque spec but if allowed to run loose it allow the pin move and start wallowing out the bronze bushings (bearings).
Roy
/ BX front axle pivot zerk #4
Roy
Reminds me to retorque my BX, specs in the Manual has it 15lb-ft
Great. Thanks for the quick replies. Now I'll go check the torque :)
/ BX front axle pivot zerk #9
Pivot pin runs through front axle housing and is lubed by axle fluid. Mine developed a leak at about 600hrs and had to be replaced (pin and bushings). I asked the mechanic if I overloaded it or didn't have the castle nut torqued properly. He said no, it's just a poor design, that the pin doesn't always get lubed due to its location in the axle housing and it can corrode and leak.
/ BX front axle pivot zerk #10
If the lube is kept to the proper level it should always be partially submerged in oil. I guess if the bushings/ bearings are a snug fit they may not get lube to them. If the lube isn't getting there, why do they leak??
/ BX front axle pivot zerk #11
I would agree, if th epivot is lubed by the axle, poor design. The designers need to re-think this one..Not to hard.
/ BX front axle pivot zerk #12
I stand corrected- the front axle pivot IS lubed by the axle oil:ashamed:
I have thoroughly perused the genuine BX24 Kubota Workshop manual and absolutely no mention or diagrams of this exist...hence my error.:eek: The manual does have a procedure for checking the pivot force with a scale rather than just blindly torquing to 14.5 ft lbs.
I will say I am astounded they designed it this way, I would have preferred to see a through tube for the axle pivot isolated from the axle oil.
Now one has to make sure this area is perfectly sealed at all times or there is a potential for lube contamination...and it is not even a real seal, just 2 O-rings according to the parts manual..
/ BX front axle pivot zerk #13
Skyco,
A couple of years ago I realized that the design was substandard. However, I did not know, or see evidence of, a hole or passage to the gear case fluids when I removed the pivot pin/bolt to fix the apparent design flaw.
I modified the bolt by drilling a .125" hole from the head end in a lathe and then a .06" intersecting cross hole. Tapped the hex end for 1/4-28 for a zerk fitting, so now it gets extreme pressure synthetic grease on the same schedule as the other pivot points on the BH & FEL.
I guess I will need to be careful to not pump too much grease into the joint (just in case there is a passage to the gear case interior).
2017 Hyundai 53' Dry Van (A62613)
2017 Hyundai 53'...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
John Deere 1025R (A62177)
John Deere 1025R...
