Tiller slip clutch adjustment
/ slip clutch adjustment #1
Combustix
NW WA
Kubota B2710
Just picked up an Ortolan 48" tiller and new pto shaft and slipclutch from EA. Was wondering as to how to adjust the slipclutch to function properly with the tiller. Thanks
/ slip clutch adjustment #2
On my tiller the slip clutch came standard and in the manual the adjustment is described as the length of the spring coil. In other words it says keep tightening the bolts until the coil is compressed to a certain length. I'm not giving what that number is because I imagine many things can vary between the makes.
If I had to guess without actual numbers given I would tighten the bolts until the spring coils are just "locked up" and then back them out a half turn.
/ slip clutch adjustment #3
Part of this is operator preference! I recommend having them as loose as you can get away with and still do the job to ensure the machine is protected.
Remember to tighten evenly and that with the first use of the year to allow it to slip to be sure that it works.
/ slip clutch adjustment #4
Here is what I do. I attach my tiller and pto shaft to the tractor. With the tractor OFF I engage the pto to lock the shaft. I loosen the slip clutch nuts/bolts until it slips easily by moving a tiller blade by hand. I tighten the nuts until a strong foot on a blade is needed to slip. I tighten the nuts 1/4 turn more and head out to some dirt. I start tilling and testing the slippage. If excessive, I turn the tractor off, tighten another 1/4 turn and till some more. I repeat as needed to get the desired level of slippage I feel works best for the ground conditions.
/ slip clutch adjustment #5
Your tractor and tiller are power/sized compatibly. The clutch should be tight enuf to bog the tractor down gracefully and stall it without slipping. - but should slip in a quick bog/stall situation. You can tell if its slipping by stopping to feel it on suspected occasions. It should not run hot. A little warm is usually about right unless youre in light going. Then it shouldnt slip at all and will be"cool".
larry
Thanks everyone I will be working on it this weekend and appreciate the advice
Dave
(APPROX. 75) UNUSED TRAFFIC CONES (A62131)
(APPROX. 75)...
Ford BS454C Tractor with Box Blade and Sweeper Attachment (A61567)
Ford BS454C...
2008 HINO 268 4X2 S/A ARMORED TRUCK (A59910)
2008 HINO 268 4X2...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
Informational Lot - Shipping (A63688)
Informational Lot...
