My new CK 30
/ My new CK 30 #1
kiotiken
Dunrobin, Ont
2012 Kioti DK45 HST Cab
After just over a year with my first tractor, a JD 955 with 1800hrs, I finally gave up investing time and money into it and opted for a brand new CK 30HST with a Woods BH70-x backhoe. The decision was made much easier after the 955 blew a bearing through the rear diff. and bleed hydr. fluid all over my rink.
My Kioti dealer, Bromely Farm Supply in Douglas Ont, loads the tires of all of the tractors they sell and come to your property to do the 50 hrs service to ensure you know how to do it properly (also free of charge). They've also agreed that they'll pick up and drop off the tractor, at no charge, for any warrantee work that needs to be done. As part of the sale, they also installed work lights (pic only show rear lights, they' ve since installed front lights) and sold me a box blade (60" agri trends (?)) at their cost.
It didn't take me long to figure out that the CK30 is significantly more tractor than my JD 955 (33hp). So far I have 55hrs (50 hr service is scheduled for later this week) on the tractor and I've done some amazing things with it.
I'd love to say it's been smooth sailing, but I have had some issues.
1) I am experiencing the foot pedal sticking, the same HST issue that's been discussed in other threads (http://www.tractorbynet.com/forums/kioti-owning-operating/217128-kioti-ck30-hydrostatic-issue.html). My dealer says he's had this before, mostly on tractors that have been worked hard. He pretty sure he'll be cracking the tractor and replacing the hydr. unit.
2) A coupler for the FEL started leaking, dealer again says he's seen it before. He fixed it and left me a spare in case it happens again.
3) Intermittently, the glow plugs fail to come on when first starting.
4) Slow cranking, may be the batt. going dead, dealer said he'll replace and check charging.
5) I found a shiny new bolt, washer and lock washer in the dirt under the tractor. For the life of me, I can't figure out where it came from. A pin on the FEL also went missing.
6) Wheel will not come off, one of the two studs with a bolt on the end spins on itself. Will probably have to be drilled out.
7) Steering went nuts. Wheel wouldn't turn either way, but pressure on it would slowly turn the wheels a random amount one way or another. Turned the tractor off, back on and I've never seen the issue again.
Don't get me wrong, I love my CK30 so far, I'm just having a little trouble building trust in it. It was the same with my 955, I said a little prayer every time I went to use it (and then usually grabbed a wrench).
Here are pictures of my new CK30 on the day I got it and a few of the restoration of my 955.
/ My new CK 30 #2
Congratulations on your new tractor. Sorry you have a few bugs to work out but sure sounds like you have a GREAT dealer working with you.
Have many happy and safe hours in the seat.
I have 330 hours on my 2008 CK35 HST & Woods BH70-x backhoe with thumb. :)
/ My new CK 30 #3
I don't think any of those things sound normal. Sticky HST pedal just means to lube the pivot. Something sounds fishy.
Why are you taking a wheel off in the first 50 hours? I've never had a wheel off.
/ My new CK 30
Well, I ran over a couple nails. I didn't notice my front tire was going down until I was turning a corner with a very large rock in the bucket. It broke both beads and damaged the valve stem. I was able to get the tire back on and it held enough air to drive it to my mechanic (auto) where they tried to take the wheel off to repair it. They ended up leaving it on, plugging the hole and replacing the valve stem. With my luck, I put another hole in the same tire (different area of my property) the next day.
/ My new CK 30 #5
Wow, Ken, that's quite a few problems, and some are quite strange!
I have 6 years on my CK30H now, and it has been great. Since I did the
final assembly out of the crate, I noticed that the front wheel studs
seems pretty soft. They would be easy to strip out with a pneumatic
gun. I never use one to tighten nuts or studs, but I bet your dealer did.
The 3 new Kiotis I have owned never had the HST foot pedal sticking
problem, but my new CT230 sure did. It was intermittant, but disconcerting
nonetheless. If I had kept that tractor, I would have tried temporarily
removing the damping cylinder to see if that eliminated the problem.
Splitting the tractor? Wow, that seems extreme. Keep us posted.
FEL bolts on new tractors all need to be re-torqued. I had several loosen
up on mine. That may be where your mystery bolt came from.
BTW, I kept one of my 955s around here for a long time, and I was
glad to have it pull my stuck CK out of the mud a few times. The JD had
new AG tires and a hoe on it.
/ My new CK 30
Well, I just got finished with the 50 hr service. Bill & Dave from Bromely came down to do the service and go over the whole process with me. I'm very happy with the service I've received from Bromely so far.
As for the sticky HST pedal, looks like they're splitting the tractor and replacing the HST unit. I know this sounds extreme and my thought was also to grease or adjust something, but I've read similar outcomes in this forum, and as soon as I mentioned the problem to Bromely, they said right away it's a problem they've been having and this is how it has to be fixed.
They pulled the rubber floor up to access two ports in the centre tunnel. They added a pressure gauge and fired it back up. It was as they expected, the pressure was much lower then it should be. They say they've had 8-10 CK series tractors, out of several hundred they've sold, with this issue, one has been replaced twice. They're ordering the parts and will pick up the tractor when they're in.
On top of the HST, they'll be replacing the starter. The issue with the slow cranking is not the batt. or a charging issue, it's the starter itself. So far, it hasn't let me down, so we'll just wait for the HST unit to arrive.
I guess there's more to come...
/ My new CK 30
The dealer was out to look at the tractor again yesterday while I was at work. He replaced the starter motor for me, and I can't believe the difference. The sound it makes is %100 different now and it starts much faster than before. This was obviously an issue from the start, I just wonder why it wasn't address before it was delivered since the guy who delivered it to me is the one who later told me he knew there was a problem the second he turned the key. It always sounded that way to me, so other than slow cranking now and then, I had no idea there was an issue.
The sticky HST pedal is a different story. I was told by the dealer that the service tech. was coming to take additional pressure tests that were requested by Kioti. When I talked to the service tech. on the phone (I was still at work), he said he had tried to make some adjustments and that's all he was able to do for now, and he didn't take any more pressure tests. He acknowledged there was a problem and it wasn't working properly, but wasn't sure that Kioti was going to cover it under warrantee and I'd have to call the dealer to discuss it. He also said there was nothing else he could do to adjust it further.
When I arrived home, I jumped on the tractor. After starting it about 5 times out of total dismay of how it now starts and sounds with the new starter, I gave the HST a try. The pedal definitely springs back faster, but the forward creep is still there. It will still move 20-30 feet after your foot is off the pedal (from a creep, not full out in 3rd gear down a hill!).
I called the dealer and didn't get the best reception from them. They're going to call Kioti today and get back to me, but they didn't sound very happy hear back from me. I just hope this isn't the start of long, drawn out fight where the dealer and Kioti refuse to do anything else, that's the vibe I'm starting to feel. If so, I'm betting I'll be told the issue was somehow cause by abuse and it's my fault. Waiting to hear more...
/ My new CK 30 #9
Thanks for the update. Sounds like you have made some headway. Just keep on being pleasantly persistent although in my opinion the dealer should make sure the tractor is running perfectly without you having to nag him.
To me the best advertising is a happy customer. :)
/ My new CK 30
I just got off the phone with Bromely and they had just got off the phone with Kioti. They are going to change the HST unit. Although I'm glad it's going to be fixed without an argument, I'm a little worried about the tractor having to be split to do it. I've heard that it's never really the same afterward, anybody ever had experience with their CK 30 split?
Just keep on being pleasantly persistent...
I'm relieved I won't have to go to war over this, as pleasantly as possible of course. I'm really trying to have a positive relationship with Bromely as I'll be relying on them for many years to come.
/ My new CK 30 #11
I'm relieved I won't have to go to war over this, as pleasantly as possible of course. I'm really trying to have a positive relationship with Bromely as I'll be relying on them for many years to come.[/QUOTE]
Don't see any reason why it would not be the same after being fixed. Main thing is they are looking after and as you said "I won't have to go to war over this".
Hope the repair goes well and then it's just many happy and safe hours :licking: in the seat. :)
/ My new CK 30 #12
I've had my CK30hst for 6 years and 500 hours of trouble free time. Sorry to hear that you have one with problems. You should be able to get any problems worked out through warranty and your dealer seems to be working to make the tractor correct.
I wouldn't be worried about the splitting of the tractor. If they know what they are doing, all will be fine. I once had an old Ford 8n apart in pieces. It worked great for 13 years and still is for the new owner.
/ My new CK 30 #13
Wow, that sounds like an unusual amount of various glitches to arise with a brand new tractor, and before 50 hours are even on it!
But I second what others have said; it sure seems as if you've gotten yourself a top-notch dealer! Splitting it shouldn't have any effects upon it's future performance at all. All should be covered under warranty also.
Enjoy your new tool & Happy future Tractorin! Greg
/ My new CK 30
Thanks guys, I know it shouldn't change the tractor, but it was actually the dealer who said they wouldn't want to split the tractor unless they absolutely had to.
For all the CK HST owners out there, here's what I'm going to attribute my HST problem to. I have no real knowledge in these matters, this is just my advice. I only started to notice the HST issue after I drove the tractor to my auto mechanic to have a leak in the tire fixed. I did this twice, and once I had the backhoe on the tractor (1200lbs according to the dealer). I used full throttle and 3rd gear (high) and drove 5 KM (3 miles). There are a few hills along the way, with one hill in particular that bogged the tractor down. I considered stopping and shifting to 2nd gear, but was nearly at the top of the hill. I have since learned (through this forum and then by talking to my dealer last night) that you should never operate the HST under 1800 rpm. I don't know for sure how low the RPM's fell up the big hill, but I'd bet it was 1800 or maybe a little lower. It was after these trips that I started noticing the creeping issue.
Like I say, I have no idea if that is what caused the issue, but it's easy enough to avoid, so I'm passing it along.
/ My new CK 30
My CK30 HST used to creep forward. I just adjusted the pedal centralising cylinder rod a fraction and it fixed it.
That is what Kioti told the dealer to try and what the dealer was out to do on Monday. The pedal definitely does come back faster now, but it still creeps. After it does finally stop for a second, it usually gives one last little jolt and moves a couple of more feet.
/ My new CK 30 #17
So looks like next time it is at the dealer they just need to tweak the pedal adjustment a bit.
I do think the you should run the tractor at no less than 2000 RPM not 1800 RPM.
I am usually between 2200 and 2400 RPM.
When using my backhoe I usually operate it at 1600-1800 RPM. :)
/ My new CK 30
Unfortunately, the dealer never mentioned anything about keeping it above 1800 or 2000 rpm, but I will definitely abide by that from now on. I rarely ever moved it under 2000 rpm anyway, mostly doing bh work.
The tech told me he had adjusted everything he could. It does seem to come back faster, but then the creep continues as before. I believe he also replaced a spring. I was told they've done all they can in the way of adjustments.
/ My new CK 30 #19
Always warm it up for a few minutes before using it (if the engine is cold). How many minutes would depend on how cold it is. I have always let it run for a few minutes at least, not that cold out this way for most of the year. After I start it and it has run for 20-30 seconds I bump the RPM to around 1400 - 1500, this gives me a few minutes to give the tractor a quick inspection for loose/missing things. I have attached the page out of the manual regarding warm up and it explains the reason why. :)
  • Warmup.pdf
/ My new CK 30
Wow, thanks MouseField. I guess that shows that I'm guilty of not reading my manual thoroughly enough. This also may explain the bearing that blew though the rear diff of my JD 955 (and resulted in my new CK30). The temp was -35 C or so. I let it warm up for a few minutes, but not 溺ore than 20 minutes as the page you attached suggested. I went from low to high gear and 5 minutes later I had a hydraulic fluid lake on my rink.
In my neck of the woods, there have been days with the wind chill below -50 C. I had no idea the warm up time would be anywhere near that long. I look forward to the dash out to the tractor in a tee shirt and slippers to start it when it痴 -40 C with the wind!
