Buying Advice Landscape uses and limitations
/ Landscape uses and limitations #1
SI2305
Gold Member
Hello all,
It has been a while since I posted, but at this time of year, I have several thoughts on my mind. I just got done bushhogging/mowing my 6 acres of tall grass. By now, that orriginal 6 acres has been trimmed down a bit as I have a substantial fruit patch and a growing orchard, all of which is located in broad paths I have cut into the tall grass (I also maintain several interconnecting paths through my tall grass--just feels fun to walk down a meandering path). I am in the process of building/creating another strip on which to eventually plant raspberries. I intend for this to be a slighhtly raised bed, and I am preparing this bed using chaff left over from the hogging & mowing. I have laid down two layers thus far. The first, six months ago has decomposed nicely and is a crumbly texture that leaves the immediately surrounding grass lush and green. I am now laying my second layer and I hope to let it decompose till spring.
This brings me to my question. I have a bad back. Previously, I hand-raked all of this material with considerably time/effort. This morning, before dawn, I was up and raking more chaff into piles that I then used the FEL to transport and dump. However, I was wondering/wishing that a landscape rake might be the appropriate tool.
Specifically, I was wondering about the following:
1) Will it pick up mowed grass clippings efficiently?
2) Will it collect hogged chaff efficiently (tends to be much longer than clippings)?
3) Will it fill so quickly that It won't really be worth the effort?
4) I have a JD 2305 and I have never been wanting for more power/torque--can it handle
a 6' rake?
5)Will the angle function create windrows or just make a mess of things
6) I don't have a MMM--I use a combination of an LX4 and a Landpride RFM (both work GREAT, but they are different beasts. I sometimes hog the tall grass,then mow the debris, makes the acreage look nice but can be time consuming) Getting a bagger is out of the question unless one is available that does not require a MMM--plus I am sure that they are spendy items anyway.
I don't really intend to MOVE the debris very far, just collect it into piles so I can easily rake it into the FEL for transport & dump. I dump all the chaff & clippings into a windrow (made by dumping from FEL) in order to make a nice, fertilebed--it is almost like making your own topsoil! I am not an organic farmer, but I do like to use some organic principles. I just feel better using the bounty of my own land to make my own food.
Another long winded question, but if anyone has any thoughts, please let me know. Also, if I missed something here, again, I am totally open to thoughts/suggestions.
Thanks in advance,
SI2305
/ Landscape uses and limitations #2
SI2305
I have seen dethachers like this on Craiglist for $200 or so - you could either tow behind your mower or make a bracket and mount on your FEL.
This would "rake" the loose material and you could push it into a pile.
I think a landscape rake would be too aggressive as there is not a lot of give in the tines and it would rip up the turf.
The benefit of mounting on the FEL would enable you to lift/lower and bunch up piles or push to your bed..
Carl
/ Landscape uses and limitations #3
Sounds to me what you need is a pine straw rake, EverythingAttachments has a new model out with replaceable tines. These leave the grass without damage but still do a good job of collecting the clippings and twigs.
Here is a few pics of mine behind my x749, this is a 6' model.
Thanks for the quick responses!
I had not thought of the pine straw rake, but it looks promising.
As far as ripping up the land, I would not use this on my lawn, but rather in my "field"--an old pasture that I try to now leave as a tall grass prarie. Local regulations require that I mow the acreage at least once per year, and I know that the tines on a rake would be aggressive on turf, but I don't really know if this is relevant on the tall grass I would be working on.
How would the tines on the pine rake stand up to the chaff left over by bushhogging? I certainly don't know/have experience here, but the tines on the pine rake look like they would bend away under pressure.
Just my thoughts, and as always, I am open to advice. Thank you for the info, I certainly will take it under advice.
thanks
SI2305
PS How broad a rake--of whatever type--could my 2305 handle?
/ Landscape uses and limitations #5
At least 6'-8' I would think, but it depends on your smallest opening/area or path.
I suggested front mount on the FEL that way you keep your mower/brush hog attached to the rear.. less changes and easier on your back..
/ Landscape uses and limitations #6
The PSR is light guessing about 60 pounds so it doesn't damage the lawn. I have used mine quite a lot and have added two 42# suitcase weights when raking some loose rocks and trash or covering seeds.
I have used it to rake my own Fescue lawn without damage, understand the above pictures were of one of my customers lawns, this lawn had previously had little care. The first thing we did was remove the pine needles so the grass could grow properly. The prior raking removed a six inch layer of old needles, numerous sticks and pine cones.
These rakes are available in 5' and 6' and I would select the larger one unless it won't fit between the trees on your property.
This is a very handy inexpensive tool, about $350 delivered, I also have a Frontier landscape rake 5' and use it where more aggresive results are needed, but if I were buying only one of these it would be the PSR.
OK, just to fill in my mental gaps, the PSR will NOT harm my lawn. Will it be sturdy enough to collect dense chaff in heavy grass? Don't get me wrong, this looks more and more like a great option, I just don't want to buy an implement that would not get through some very heavy spots
Thanks for all the advice,
SI2305
Carl,
I truly appreciate your thoughts/concerns for my back. It has really intereared with things I never thought twice about before. I have two specific thoughts:
1) will the dethacher hold up under all the grass clippings I am going to through at it? I am not using it for the lawn, but for 6-7 foot tall grass that has been hogged, a process that leaves some pretty long clippings and generally just a LOT of matter left behind.
2) can I simply scoop up grass or rake in grass pile into the bucket and use the FEL as usual with the dethatcher still attached?
Thanks for your thoughts, I had never thought of either of these items before and I certainly am thankful for the thoughts.
SI2305
JD2305, CX200, LX4, LandPride 60" RFM, 60" grader blade, extra forward light kit, Pat's Easy Change
/ Landscape uses and limitations #9
SI2305
I like the pine straw option as it has a much larger area/capacity to collect grass and spring loaded tines. The dethacher has limited capacity but was what came to mind.. thats why its great to have others chime in too.
Here's a 5' one $175. seems reasonable but who knows with shipping the total cost. 5' NEW Tractor Three Point Hitch Pine Straw Rake | eBay
The other thing, I have seen brush hogged fields that were not "clean" but left the grass matted down and not all cut. If its matted down any rake will be tough going pulling out clumps of grass and soil too.
The dethacher is meant to be front mounted and the pine straw rake rear 3PTH. The best would be the pine straw mounted on the front (if you want to elimnate changeover) but for the price I would get the 5' one and use it as a 3PTH model then modify if you want/need to.
Its like a big yard rake IMO..
/ Landscape uses and limitations #10
Carl,
Might I ask what the gap is between the tines? I am constantly looking for a better way to rake horse apples in the pasture to help them breakdown.
Thank you in advance,
lost
/ Landscape uses and limitations #11
Lost,
I dont know - would envision an 1". Count the tines on the ebay one - sounds like too much fun?
jenkinsph actually suggested this and has one similar to the one shown... he his much better position to reply.
Carl
/ Landscape uses and limitations #12
About the pine straw rakes, the new ones at Everything Attachments have individually replaceable tines. Much easier to repair than the ones with all welded connections.
If you are referring to the stems as chaff then the PSR will do a good job of collecting. One of the things I like the most about these rakes is 90% of the time everything falls away from the rake tines when you lift it up. A hand leaf rake gets clogged frequently, not the case with these rakes.
What I do is rake the debris into a pile with the mower then pick up the piles with the fel and load into the dump trailer and haul off. There is some raking needed around trees and tight spots but not much. This is about as mechanized as I can get.
About the tall grass, shouldn't be a problem raking any of this up. I would question doing this on a regular basis though, I find it much more beneficial to the ground to mulch this up and allow it to return to the soil.
/ Landscape uses and limitations #13
Lost,
Carl
The tines are on 2" centers and are about 5/16" diameter.
/ Landscape uses and limitations #14
Thank you sir. I didn't mean to hijack this thread but this interests me for breaking up horse apples in an established pasture. Right now we use a homemade drag of chain link fence, 4x4's and tires (as weight).
Thank you again
/ Landscape uses and limitations #15
Thank you again
You are welcome.:)
Heres what I use for pastures for cow patties and the like, between the PSR and this home made harrow it makes it all easy and quick. I built this about two years ago for $250.
/ Landscape uses and limitations #16
You are welcome.:)
Steve,
You have all the "right" tools for the job(s) by your pics and signature line.
Nice work on the harrow too.
Carl
/ Landscape uses and limitations #17
Steve,
Carl
Thanks, I just like using and building this stuff, guess it is my collection of toys.
jenkinsph,
What you have shown me looks like very sound advice. As far as the over-raking of the tall grass, this is not what I intend. As I stated before, I have about 5-6 acres in tall grass and I rake perhaps 1/10 acre in order to collect clippings for along compost windrow about 30 feet long by about 4 feet wide by however tall I can get this to remain stable. For the most part i like having my grassland in a natural condition as possible, but as I stated before, I just appreciate using my land's own bounty to help fertilize my crops.
2 years ago I had a similar project where I just racked all the chaff I could over about a 20' diameter circle and added lawn clippings when they were really excessive (and otherwise left them alone), and I added coffee grounds & food scraps. It made a pile about 5' in diameter by about 5' tall. This was my compost heap for the year. By spring the next year, it had rotted into a pile about 2' tall. I then moved it into a prepared bed.
One of the most amazing aspects of this technique is that the grass downhill (and one peach tree I planted) grew as amazing rates and were just lush green. The spot itself produced huge grass stalks. All of this from a 20' diameter circle out of 5 acres of grassland.
I agree with you, I would not want to overtax my land, but all I do is rake from a different spot the next year.
Thanks much for your advice, I will seriously look into the PSR.
SI2305
/ Landscape uses and limitations #19
Hello all,
a 6' rake?
Thanks in advance,
SI2305
I like the same things, but I have taken to building the compost in it's own pile, and then moving it where I want with my loader, or the trailer.
I sure like that pine straw rake too! I'll have to go to Everything attachments, and check it out some more.
/ Landscape uses and limitations #20
Chuck,
Looks like you have last years leaves composting in one pile then loam and another aged compost pile there. I do the same with an active pile and a composting one.
Every year I collect 20+ yards of leaves in Oct/Nov sprinkle with a little 10/10/10 and lime and turn every few weeks. By this time of year its great material for top dressing the yard mixed with a little loam.
Been looking for a small manure spreader to use to top dress - saw one on ebay and CL but didnt get it.. Now looking to build a spreader. I looked on line and seems $1000 is the asking price or more, and then old spreaders that are large are too big..
Have you or does anyone have ideas/built a compost spreader to evenly spread it out? The FEL drops clumps then need to rake in and its not uniform.
Carl
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63118)
2017 Cadillac...
2015 Ford F-550 Crew Cab Service Truck (A61568)
2015 Ford F-550...
2005 John Deere 210LE 84HP Loader Utility Tractor with Box Blade (A61567)
2005 John Deere...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
BOSCH BULLDOG XTREME ELECT. HAMMER DRILL (A62131)
BOSCH BULLDOG...
2011 Infiniti QX56 Multipurpose Vehicle (MPV), VIN # JN8AZ2NEXB9001685 (A61165)
2011 Infiniti QX56...
