What truck to pull Kubotas
/ What truck to pull Kubotas #1
foreman Etexas
Elite Member
texas
Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
Im heading out to look at New Truck today,was wondering what new trucks TBN members are using. Im thinking about the gas over the diesel this time but still havent desided.Im also wondering if going to a 3/4 or stay with the 1ton single or dually.I do own a small dozer D31p and cple tractors one lease place around 40 miles away. I will also be running out of state to get hay. My pick so 2011 GMC crew/cab 2500,4x4,duramax,im usually a ford man but I just dont know yet.Budget:$55,000
/ What truck to pull Kubotas #2
What kind of diesel truck do you have now? I have an '08 GMC 1500 that loves gasoline.
/ What truck to pull Kubotas #3
There is a lot more leg room for the back seat in the Ford than the GM on the crew cabs. Ford also has some better technology features if you're into that. GM is just stuck with onstar. Ford's sync system integrates with your smart phone. The GMs are nice but I'm into the features and comfort.
/ What truck to pull Kubotas #4
BTW I've owned mostly dodge trucks.
/ What truck to pull Kubotas #5
Doesn't sound like I'm towing anything as heavy as you.
I use a 2006 Chev Silverado 4x4 1/2 ton extra cab 5.3L V8 to pull the BX24 on a dual axle TuffTrailer. The Chev pulls that little load without effort, and gets decent _gas_ mileage when not towing. I'm 6'2" and I like the extra cab for the added room and "junk drawer" effect.
When pulling the 7500lb boat, I use a '98 Suburban 4x4 w/454 and 4.10s. Pulls great. Gas "mileage", what's that?
YMMV,
Z.
00 FORD F-350 crew cab,dually,7.3diesel,6spd (145,000miles)in shop now,antifreeze in fuel system
/ What truck to pull Kubotas #7
My pick of trucks you mentioned is The DEISEL I ton SRW.
The 3/4 tons are a whole lot less truck for a very meager savings of dollars.
The diesel gets more miles per gallon and could enable you to get home delivery of less costly off road fuel for your tractor or tractors.
/ What truck to pull Kubotas #8
Around here if you cross the state line (in either direction) and have a dually pulling a trailer you can expect a 50/50 chance of being pulled over unless you have a DOT number. Personally I would love to have a 1 ton dually with a gooseneck trailer. Chances are though the 3/4 ton would be more than enough truck.
Drive both. I ended up with a Tundra after leaning hard for a Ford but during the test drive I found that the transmission had a shift point that was right at 50mph. It got annoying having it shifting into overdrive then back out while just driving on a slightly hilly road, something there's lots of here in VT.
Yeah I have been looking at them dodges I have always like the cummins diesel,but the interior is kinda plain in them. I could always just keep the old ford to pull the Dozer,dont really move it all the time(if I went with a 3/4ton).Already own 5vehicles just didnt wont to add another.Plan was just to sell the old ford once I got the motor fixed(in shop now)just time for upgrade (reliability).
/ What truck to pull Kubotas #10
Diesel all the way. I'm not sure about the brand new trucks but my 2004.5 Dodge Diesel has plenty of power and gets great mileage. 21 to 22 Highway! It's 4x4 3500 6 speed with SRW short bed. I plan to keep it forever.
If I were you... I would seriously consider finding a used Dodge Diesel... either a 2004.5 or 2005 model. You'll have half your budget left to put back in the bank.
I cannot speak for the new Ram trucks. I do like Cummins engines though. A lot of guys like their Duramax powered machines. One thing is for certain... I would not buy a Ford Diesel. The last good engine IMHO was the 7.3L.
Good luck.
Good luck.
Yeah thought about the used truck again but I am just gonna buy New since I will be keeping it for awhile and used well just dont know what your getting.
Well I figuerd I would show my tractors that I have so yall get an idea of what im hauling tractor2.JPG
Also truck will be used to haul hay and cattle
/ What truck to pull Kubotas #13
Have a '10 Chevy 2500 gas that pulls well. The only reason to get the diesel is if you pull a lot. Higher motor and fuel cost won't pay off on the diesel unless you use it for pulling a lot. Pulling weight will make the difference on the 3/4 to 1 ton and single or dual wheel questions.
Sync system is nice, but you can connect your cell to the GM products using the same Bluetooth the Sync system uses. Difference is the sync system has that nice big screen up front in dash. GM's navigation is just given by voice commands and text instructions on radio display.
/ What truck to pull Kubotas #14
Well I figuerd I would show my tractors that I have so yall get an idea of what im haulingView attachment 227033
Your in 1 ton diesel dually territory in my opinion! Maybe 1 ton SRW diesel...
I would even consider buying something bigger than a pickup... something like an F650... You know like a beer tractor trailer. I know there's some nices ones out from Ford, GM and maybe Freight liner. A lot of guys use this size to pull big 5th wheels. Plus you can get CAT engines in some of them! Purrr power!
/ What truck to pull Kubotas #15
Definatally a vote for diesel from me.
With the loads you are talking, even your tractors, it is really going to labor a gasser. Gassers are for CUT's and SCUT's. You are looking at what appears to be a 10k towing load at a minimum. With the tractor + trailer.
I have a smaller tractor and even went diesel dually this time. VERY nice. I didnt buy new though. I guess it was all the emissions garbage and DEF/urea that scared me away. SO that is also something to consider on these newer diesels.:confused2:
/ What truck to pull Kubotas #16
I can relate a little since we've used a '99 F-250 PSD, 6spd. for farm towing duty for years, this past year dad got a '10 3500 cab-chassis Dodge, 6.7L, 6pd. He's a die hard manual transmission guy (as am I) and Dodge is the only choice still left in that market.
Anyways, a few observations on the new truck vs the old. The dodge definitely handles big trailers easier. Dually, heavier springs, better brakes, etc are all nice for towing. As far as power goes, it definitely has more power than the 7.3, but it is less useable IMO. If you get the right gear and right speed it will put an 18K trailer up hills pretty quick. BUT, the power range is very limited. Torque below 2,000rpms is non-existent, and it red-lines just a little over 3,000rpms, so there isn't much to work with. Wouldn't be a problem if it had 9+ gears, but as it is it's not optimal. Off-idle torque is very poor compared to the 7.3, with the dodge if you don't give it some throttle when you are trying to get a load moving it will stall out, not the case with the ford. Fuel mileage is about 10mpg for both when towing about 15-18K.
I'm not bashing the dodge, it's a great truck and tows much better than the old ford. However, I think these new 'high power' diesels are way over-rated. Sure it makes huge HP and Torque numbers, but it's in a very limited rpm range. Heck, it feels like my old gas powered F-250 (460) has more low end torque. Maybe that's why they've all gone to automatics nowadays, to better use the peaky power, IDK.
Personally if I were buying a new truck it'd have a gas engine, ten years ago I'd have gotten a diesel.
/ What truck to pull Kubotas #17
I started buying diesel trucks in 2004 one in 06 and 08 and I will never go back to gas. If you need to tow it's not all or nothing it's diesel or nothing for me. I tow a 34 ft enclosed trailer with either a car or my tractor in it and I have 10k behind me. I once towed half a house that was dismantled and placed in my trailer and I tipped the scales at 24.5k total. I pulled through the adirondacks and passed a gaser going up hill (two lanes in my direction) gas is something you pass not something you own
/ What truck to pull Kubotas #18
I'd go with a diesel pulling those rigs. If you go with a gas burner I recommend Ford, their auto transmissions hold up a little better than the competition. Diesel with auto, hard to beat a Duramax. If you want manual, that Cummins will serve you well. I love my Duramax, just rolled 100000 and almost broke in!
/ What truck to pull Kubotas #19
I have had them all, the 7.3 is a great motor if you don't mind rebuilding the trans every 40k and the cummins is the same. They just devour automatic trannys. I have had 5 or 6 6.0 PSD and they pulled good but .... Well you know the rest. I now have a 09 F 350 drw with a V10 and that is a nice combo but 8-9 mpg is a kick in the stones. I also have a 11 F350 SRW 6.2 gas that gets 15 ish mpg but does not pull near as nice as the V10
/ What truck to pull Kubotas #20
if i was you id look at an f450 ford diesel truck.it would be a stouter an stronger truck than the f350.
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
