Front-End Loader Cutting edge vs. Tooth Bar on the Bucket???
   / Cutting edge vs. Tooth Bar on the Bucket??? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I'm buying my tractor and getting it outfitted.
Can someone explain the pro/cons and useage of a Tooth Bar and a Cutting Edge.
Which one and why, or do I need both?
I will be doing brush clearing and leveling and cleaning up land after the mulcher grinds stumps & slash. I will also be clearing and putting in trails, maintaining dirt access roads for fire prevention/fighting etc.
Thanks in advance,
David
   / Cutting edge vs. Tooth Bar on the Bucket??? #2
My toothbar gives my FEL enough of an underbite to make picking and moving both woody debris and solid objects a little easier. It's also good for "raking" out surface roots. I've also hung a chain from a tooth or two and used it to suspend and carry various items. Most recently I used it to remove an old signpost.
I go toothbar-free when working snow or backdragging gravel in the driveway.
   / Cutting edge vs. Tooth Bar on the Bucket??? #3
Your bucket already has a cutting edge on it.
The toothbar is an add-on and makes digging easier. Also useful for brush moving.
I want one real bad.
http://www.wrlonginc.com/FTB.htm
   / Cutting edge vs. Tooth Bar on the Bucket??? #4
A tooth-bar is a very handy and fairly inexpensive addition to a bucket.Easily removed for back blading,snow removal ect.Mine with the Green's Machine Thumb works great for brush removal.A lot easier digging with the tooth-bar on.
NY,
I'm being quoted $350 for the toothbar.
I LIKE the Green's Machine Thumb!!! That may be just the ticket for me!
Thank you!
David
   / Cutting edge vs. Tooth Bar on the Bucket??? #6
NY,
Thank you!
David
It is, the ones from WRLong look way too large for your application.
   / Cutting edge vs. Tooth Bar on the Bucket??? #7
Thanks in advance,
David
Hi David,
I think you are talking about a "Hard Edge" & Tooth bar.
Your bucket has a built in cutting edge. Depending on how much and how hard you use it. it could last a long long time. For hard use on concrete or lots of stone you want a Hard Edge.
If you get a tooth bar. you want it to easy to remove or put on. It's not real goof for smoothing driveways or roads.
Hope that helps.
   / Cutting edge vs. Tooth Bar on the Bucket??? #8
Your price on the tooth-bar is about right.the expensive part of the grapple is the third function valve.You may want to include it with your tractor purchase.
$700-$1,000.I think I paid about $470.00 for the thumb.
NY,
Did you do the thumb install yourself or did you find a dealer?
I was talking to a different dealer and he told me the hoses, quick connects etc wil set me back over $100 each PLUS I still will need to drill or weld the thumb on.
That might be beyond this computer geeks capabilities.
David
   / Cutting edge vs. Tooth Bar on the Bucket??? #10
By all means bolt the thumb on.You may want to remove to do dirt work etc.
I had to weld an angle on top and bolted thru.the angle also reinforces the top of the bucket.
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55314)
2012 NEW HOLLAND...
American G-Model Pump Jack (A55315)
American G-Model...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
