ayelvington
Gold Member
Black oil in a diesel is normal. Don't waste your time changing it unless it's either a) time to change it, or b) you know there is a problem (water, etc.).
Excess maintenance can be the source of as many problems as deferred maintenance.
Doing the front axles at 50 hours on a BX is a good idea for at least two reasons: a) it gets you to check the fluid level, and b) the axles work HARD and you will see metal in the fluid. Don't panic, this is as normal as normal gets. Just be sure to keep an eye on your axle fluid level, especially if you use 4WD a lot.
TRUE CONFESSION: I am a sinner, and I change the oil ONCE A YEAR. (period) I use my little friend A LOT, and changing oil by the clock would wear me out. Use a high-quality synthetic oil and keep an eye on the level and you won't have trouble. (A block heater for cold winter starts is a very good idea if you plow snow like most of us over here do. It gets your oil moving through the channels more easily and to where it's needed.)
My two bits, now you all can poke at me!
