Pat's Easy Change Easy change 3-pt system for Mahindra Tractor
   / Easy change 3-pt system for Mahindra Tractor #1
coronelli
Doss anyone know of a good easy change 3-point system that will fit my Mahindra 5500? I looked at Pat's, but it only fits lift arms 2-3/4" high. The lift arm's on my tractor flare out to 3-1/2" high.
   / Easy change 3-pt system for Mahindra Tractor #2
i have a 4500 i bought in jan. and the pat's system fit just fine,i had to call the company to get a cat 2 system as it was not listed on their website order sheet,once i installed it i was very happy with it!
   / Easy change 3-pt system for Mahindra Tractor #3
I've been looking at the Pat's system for my Mahindra 5500 4WD but I am concerned about changing the lift capacity by extending the arm length! I am using a John Deere 7' bush cutter and my tractor barely picks it up now. i'm not sure I haven't damaged my lift already because even with a lightweight implement, I have to move up my rpm's above a fast idle to get full lifting height. Does anyone know if this is normal and how high my lift should go? Should I be concerned about using the Pat's system?
Thanks!
   / Easy change 3-pt system for Mahindra Tractor #4
Thanks!
Published specs on the 5500 show that it has a lift capacity of over 3900lbs! I don't believe that the couple of inches that the Pat's hooks add are going to cause a problem with lifting just about any implement. Do you run your tractor at somewhere close to idle speed? I know that with my hydro I need to run it at a min 2000 rpm to have hydraulics all function properly.
   / Easy change 3-pt system for Mahindra Tractor #5
RJFCO,
If you have a manual, check in it for the hydraulic trouble shooting section. Or go to Mahindrausa.com the at the top of the sit is a 24/7 Customer care window. All you will need is the tractor serial number (lower case when entering) to locate your tractors section. Another thing is have you checked your fluid level. Another way would be to post your inquiry in the Mahindra forum here in TBN. Your tractor has a 3969lb max lift capacity on the 3pt with the 11 gallon per minute flow rate. The same that I have with my 5530 4wd.
idaho2
   / Easy change 3-pt system for Mahindra Tractor #6
RJFCO,
idaho2
What idaho2 said :thumbsup:
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2013 Infiniti JX35 SUV (A55853)
2013 Infiniti JX35...
2012 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A55745)
2012...
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
19010 (A55851)
19010 (A55851)
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A55745)
2014 AMERITRAIL...
