Finally got new Deere 2520 this weekend
/ Finally got new Deere 2520 this weekend #1
Strangerover
Ludlow, MA, USA
2011 John Deere 2520
After waiting 2 months, I finally got my new 2520 this weekend. It has the 200cx loader w/61" bucket and 46 backhoe. Put about 3 hrs on it so far, mostly "feeling" it out and learning to use the backhoe. It is my first tractor, so I really have no reference to compare it to. Plan on getting a box blade to help spread some dirt. Love that diesel drumming!
/ Finally got new Deere 2520 this weekend #2
Congratulations! :)
/ Finally got new Deere 2520 this weekend #3
Congratulations on the new tractor.:thumbsup:
Get some seat time and enjoy it. A word of advice with the backhoe, watch that you donlt hit the stabilizers with the bucket.
Thanks, and duly noted on the backhoe tip. Any tips that would help a newbie are welcome. I have about an acre of woods behind the back yard on a very rocky piece of property that I want to tame, so the kids can use it. I think I need some forks to help pick up + move some rocks around. I also want to spread some dirt around where the lawn has settled since construction 5 yrs ago. How much abuse can one of these rigs take, as far as bouncing around on less-than-even terrain? Has anybody broken the cast steel "backbone" in the middle (under the floor) or the hub reduction boxes @ the rear wheels? Those just (visually) seem like weak links if things got rough, but what the heck do I know? Don't get me wrong; I'm gentle on it & realize it's not a bulldozer or serious construction equip, + I'm scared-stiff of tipping it over. Wish I could afford some implements & attachments, but it took all I could scrape up to buy the machine. Gotta put some water back in the well!
/ Finally got new Deere 2520 this weekend #6
Strange,
Congratulations! I'm sure you'll love the machine.
Here is a tip: If/when you need to detach the loader bucket (to attach your forks, etc.) don't get lazy and try to leave your lynch pins hanging by their cables. They will get caught under the bottom of the bucket mounts and break the cables. It's better to get in the habit of reattaching them to the extra mouning points on the bucket mount when they are not in use.
Not a big deal, but a way to preserve the cables.
Also, be gentle with your range shift lever. There have been threads on here about the pins that hold the levers breaking off inside the case and it's a bear to fix.
Oh, here's one more thing I learned. If you need to attach a drive shaft to either the mid or rear PTO, shift the PTO control lever to the opposite PTO from the one you are using. This allows you to easily rotate the PTO stub to line up with the splines on the drive shaft. It is a REAL pain in the neck to do it otherwise.
I wish you the best of luck with your new machine!
/ Finally got new Deere 2520 this weekend #7
In general, the 2520 seems to be a pretty stout little tractor. As with anything, it's possible to break it if you push it well beyond what it is capable of. If you stay within the range of attachments that were designed for use with a tractor of this size, you shouldn't get into trouble. Proper ballasting will help a great deal with the FEL.
If you haven't already had it done by the dealer, make sure the rear tires are set to the wide stance (valve stems on the inside). This will make the tractor more stable, especially when using the FEL.
/ Finally got new Deere 2520 this weekend #8
Congrats on your new machine!:)
I'm thinking you will thoroughly enjoy your 2520.:thumbsup:
Yes!
Not sure which forum,but someone broke a reduction hub on his 2520.
BUT!! As you stated,if common sense is constantly in use,these kinds of things won't happen.:thumbsup:
Greg
How much wider does flipping the wheels make it? Thanks for all the tips, btw! Also, has anybody used the loader bucket to push snow? I realize it's not ideal, but does it work at all, say, in "float", or am I just going to make a fool of myself trying? I can't really afford a plow attachment for a while. Don't want to embarrass team green. How much traction do the R4's get on pavement pushing snow? The drive is a long, gentle slope.
/ Finally got new Deere 2520 this weekend #10
Flipping is about 2 inches. The 200cx manual recommends the wide position.
As for using the loader for snow removal, it does a good job but is slower than other methods. If you think you'll embarrass team green then I've doing it for years as a loader is all I've used. You'll have to see how the traction goes, I do not run chains but others do. I just push the big stuff down hill. My drive is gravel so I leave a snow layer down. Chains may mark your asphalt and that is something to think about.
/ Finally got new Deere 2520 this weekend #11
Of course we don't get as much snow here, but a combination of the loader and a rear blade works pretty well if you're not in a hurry.
Even new rear blades are pretty inexpensive and they are handy for other things. If you turn them around and angle them, they work pretty well on asphalt without too much damage.
/ Finally got new Deere 2520 this weekend #12
I used my loader (61 inch bucket) and rear blade to clean a couple of 12 inch snowfalls (gravel drive) and was surprised at how well it did. I also have a front blade and 54 inch blower, but was too lazy to remove the loader and install the front quick hitch.
Anyway, the way I did it was set the loader bucket so that the leading edge was tilted up about an inch above the gravel. Then, I marked the buckt angle gauge with a felt tip pen so I'd know exactly where that point was. After that, I just dropped the bucket and ran down the drive in "float" mode.
Worked well and did not dig into the gravel. Of course, I had to make a few turnouts to push the snow off to the side and when I got to the ends, I moved the piles out of the way with the loader.
During the process, I also had the rear blade (60 inch with gauge wheels) down and angled so it was pushing the remaining snow off to the side.
I have 320 lbs of wheel weights and do not use chains. It plows much better with the ballast box (809 lbs) on it, but, of course, can't do that with the rear blade on it.
Overall, I was pleasantly surprised with how well it did plowing snow with the loader.
/ Finally got new Deere 2520 this weekend #13
First year I had my 2520,that's what I used for snow removal. It worked pretty darn good. Ironically,I broke my tractor in on a 2 foot snowfall,and IMO,other than a blower,a bucket was probably the only way to go with that much snow.:thumbsup:
Greg
/ Finally got new Deere 2520 this weekend #14
This is excellent advice! I've had my 2520 since June and plan to use my 200CX for snow removal this winter. My only question - with the discussion I've read on the forum as well as in the manual, it almost seems like there's a way to "enter" and "exit" float mode with the loader. I have spread a lot of gravel for our driveway with our new home and have tilted the bucket down and back-bladed it to smooth and even it out. Sometimes it seems to hold and do a good job of pushing, but other times it seems to float over the gravel. To fix it, I adjust the tilt on the bucket and it seems then to dig... but I don't really know what I'm changing besides the angle.
This is probably pretty elementary, but how do I know when I drop the bucket whether I'm in float or not?
Thanks for any help... I'm at 13 hours on my 2520 and absolutely love it!
/ Finally got new Deere 2520 this weekend #15
When you push the SCV lever all the way forward, there is a "catch" in the feel of the the control lever. That's the float position.
/ Finally got new Deere 2520 this weekend #16
Got it. Thanks a lot! I had never intentionally tried to push the SCV over that "catch" before.
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A64194)
2025 LandHonor...
2017 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2017 BOBCAT MT85...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
