Going Green
/ Going Green #1
lakngulf
Lake Martin Alabama
Kioti CK30
"Going Green" is a hot topic these days, but I am writing just about the work involved to get more green grass. When I purchased my place in 1996 I had a strip of centipede grass about 20-25 feet deep. I could mow it in five minutes. The rest of my yard I decided to leave natural, and let the pine trees give it a good cover of mulch. Well, centipede gives out fast growing runners, and the grass has crept up the yard over the years.
Last year I decided that one larger area would look a lot better if it was green, so I planted some plugs in that area to see if the centipede would take hold. There were a couple of long strips, but most of the plugs were with hole diggers. I would dig a plug in the dirt area, get a plug of centipede to put in the hole, then dig another hole, put that dirt in the most recent centipede plug hole, and do that over and over again. Well, it worked. Here is an area that was all dirt and pine straw last summer:
That worked so well that I decided to give a try in another area. This area, however, had lots of roots showing, which meant there were many just beneath the surface. I used the box blade diggers to grab and loosen the roots, so the centipede grass will not have so much competition. During that process the area looked like a war zone:
I loaded the roots in the FEL bucket and hauled them off, then smoothed the area with the box blade.
The plugs for this area will come from along the seawall. We have decided to plant a row of iris' there, for a good look and for a barrier to keep four grandchildren ( and more on the way) from getting too close to the edge.
/ Going Green #2
Looks great. I like centipede grass as well. Its the best walking thru it barefoot in the summer and it never clogs the mowers.
One trick I do, is I clip the runners off the sidewalk and in any pinestraw beds. Take each runner and cut it into about 4 inch long strips, stick em in a small pot...usually two to three to a 4 inch pot in a light mix of recycled potting soil, grow em in that for a month or so, than plant as needed. It works good and you can time it for planting after heavy rainfall so they dont dry out.
Just another method.
Tom
/ Going Green
Looks great. I like centipede grass as well. Its the best walking thru it barefoot in the summer and it never clogs the mowers. Tom
It is a good grass, and seems to like the weather fine at my house. I give it plenty of water and weed/feed once a year. About a month ago I did throw some additional 15-0-15 on the new grass. It now has a much darker green tint than the main yard.
It does feel good to the bare foot, and really can go awhile without being cut, although I do cut mine often.
/ Going Green
Here is my sod farm. Not much fun with 97% and high humidity.
Calls for a simple plan: Dig up a little grass, then jump in the lake
/ Going Green
The transplanted grass is doing pretty good. I am keeping it watered in this 100 degree weather we are having.
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
