Comparison Can someone confirm Bobcat Tractor is built by Kioti?
   / Can someone confirm Bobcat Tractor is built by Kioti? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Also,
Is Bobcat better than Kioti?
Why?
Can I get 4wd on Bobcat Tractor? (their website stinks and was unclea on this)?
I'm a newbie shopping for the biggest tractor for he least $$$ total cost.
Thanks in advance,
David
   / Can someone confirm Bobcat Tractor is built by Kioti? #2
Same tractor. Daedong- Korea. Also sold at McCormick in red, I believe. Of course, different loaders may apply. May also may want to price an LS, as per your desire for biggest bang for the buck.
   / Can someone confirm Bobcat Tractor is built by Kioti? #3
Bobcat and Kiota are owned by the same Korean company.
   / Can someone confirm Bobcat Tractor is built by Kioti? #4
Confirmed - sort of. Daedong builds both in South Korea. The plant is here 1-12 Buk-Ri, Nongong-Eup, Dalseong-Gun - Google Maps.
Also,
Why?
They are almost the same thing, sharing many parts. However, Bobcat and Kioti each offer different attachments, so you need to look at those. And you want to be sure you like the particular dealer for the one you choose.
Yup. I believe they are all 4WD. As are the Kiotis.
You're on the right track. Both offer great value and excellent quality. Get out to your local dealers and test drive them! Have fun.
I don't believe Bobcat is owned by Daedong. Rather, Bobcat buys tractors from Daedong.
whiskywizard,
My research lead me to the fact they were different companies, but I suspected Kioti was building the Bobcat tractors...
PS - Do you distill?
Thanks,
David
Which loader is better?
LS? which company is that?
Thanks again,
David
How do evaluate their attachments?
what criteria do I use to evaluate them?
Remember, I'm a novice and easily impressed by shiny stuff and chrome...
   / Can someone confirm Bobcat Tractor is built by Kioti? #10
Thanks again,
David
Here are the spec sheet links for the loaders. I've never heard of one being unreliable in any way. Other folks will chime in here if they have experienced problems....
Kioti
Bobcat
What size tractor you're looking for?
LS Tractors seem to be gaining popularity. I'm not very knowledgable re LS. Others here can offer more info and of better quality than I can.
I had lots of experience with larger tractors but none with compact utility tractors, so I had to do the same research you're doing now. My secondary research led me to Kioti. So far, I'm very happy with my little 2011 CK20S with hydrostatic transmission. It does more than I need in my current situation.
I too looked closely at the differences between Kioti and Bobcat. I had no problems with the Bobcat company or the tractors but wasn't thrilled with the dealer.
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
Informational Lot - Financing (A55315)
Informational Lot...
BOLTS, NUTS & WASHERS W/BIN (A55745)
BOLTS, NUTS &...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
