Brazing a weight lifting plate
/ Brazing a weight lifting plate #1
BeezFun
Elite Member
IL
Kubota B2710
Trying to Ox/Ac braze collar to weight lifting plate shown in photo. Using flux coated bronze rod. Makes a big mess but seems to hold ok. Surprisingly the plate seems to take the braze better than the little collar. I ground both down first so they're clean. I'm using a large tip on my torch, it gets things hot but I don't seem to be able to control the flow of the material. Any help appreciated.
/ Brazing a weight lifting plate #2
How I learned to do it is to heat the base metal to a dull cherry red, and let the heat of the base metal melt the rod, not the torch. If you have the metal glowing bright red or orange, it is too hot, if you have to melt the rod with the torch, it is too cold. Think of it more like soldering then welding.
Maybe that's why the plate takes the rod better, it's not so hot. I have one more to do, will try again. I don't have a rosebud, maybe that would be better.
/ Brazing a weight lifting plate #4
I would just use a big welding tip for that, if your biggest welding tip wont get it hot enough, in a reasonable amount of time, just use a cutting tip, but dont push the cutting leaver.
/ Brazing a weight lifting plate #5
Hot enough to melt the bronze is hot enough. I love brazing stuff. It can fix a lot of things.
/ Brazing a weight lifting plate #6
Oh deereman, you are such an expert on fabrication! I find your posts very entertaining, keep practicing with your 6010's and your ac welder plugged into your clothes dryer outlet.
/ Brazing a weight lifting plate #7
I actually have done a fair bit of brazing, before I got a welder. I have never used a 6010 rod with an AC welder, the 6010 rod is a DC only rod, and would not work at all with my tombstone. As for the dryer outlet, I have finaly wired the shop with 220v power (on its own circut), the clothes dryer was just for until I wired the 220v. I have probably got a better set up then what you did when you were 14, I already have a tombstone, and a $700 air compressor, and a whole wack of power tools. Also, I didnt see you giving any advice on the brazing, if you post, post something helpful, not something that has nothing to do with the question, and only insults people.
I was using my biggest welding tip, cranked up the flame quite a bit more on the second one and that seemed to help. I also did better preparation and fluxed the surfaces before I started. I think the plate was just such a huge heat sink that it was very difficult to keep it hot enough over a larger area without melting the parent material in one small spot. Anyway, the job's done now.
/ Brazing a weight lifting plate #9
I do think that the huge mass of cast iron was making it harder to braze, glad you got it done. Why did you have to braze flanges onto the weights anyways?
/ Brazing a weight lifting plate #10
Deereman if you are 14 yrs old I do apologize, I did not know you are a up and comer. Glad too see the younger generation eager to learn the trade! Sorry bud! I feel bad now and may have to donate you a dc machine! :(
/ Brazing a weight lifting plate #11
Thats alright man, I am 14, and I didnt take much offence from that. I wouldnt mind a dc machine though:D
/ Brazing a weight lifting plate #12
Allright bud! Called me out on that one, but your paying the shipping!
/ Brazing a weight lifting plate #13
Whats the machine. And I hope you dont live in mexico, that would cost alot to ship.
/ Brazing a weight lifting plate #14
I got a miller thunderbolt I would let go,and im in germany. Only kidding, western NY, southern teir. Where are you
/ Brazing a weight lifting plate #15
I am in british columbia, the opposite side of the north america from you. I will sadly have to decline, it will cost more to ship it here then to buy it local. Oh well, I guess I will just stick with my lincoln until I get enough cash for the ESAB mig I am looking at.
/ Brazing a weight lifting plate #16
Ok bud, wanna make my way towards BC one day, big bowhunter, and would love to get after some mountain goats! Well be in touch through tbn!
/ Brazing a weight lifting plate #17
Ok great, I have sure seen alot of mountain goats in the rockies, I go there every summer, probably good hunting.
/ Brazing a weight lifting plate #18
I'm sorry, but I'll have to disagree.
The base metal has to be hot enough to accept the bronze. Otherwise, the bronze will just set on top in globs without melting into it and making a strong bond.
/ Brazing a weight lifting plate #19
I was talking about the metal. What else but the rod is there? Anyway, when the bronze flows, it's hot enough. Any more heat than that isn't needed. The guy who taught me was eight years older than the twentieth century (if you asked him his age). Now I'm gettin' kind of geezer too.
PALLET OF WOODEN STAKES (A68842)
PALLET OF WOODEN...
MAXEY PORTAPOTTY VAC TRAILER (A67714)
MAXEY PORTAPOTTY...
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A69167)
2006 CHEVROLET...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
