Countdown to Plug in Hybrid CUT?
   / Countdown to Plug in Hybrid CUT? #1
MiserableOldFart
Delaware County Catskills NY
NH Workmaster 40, Kubota GR2120
With the plug-in hybrid cars beginning to come to the fore, and Volvo's diesel plug-in on the market now, it would seem that tractors would be a natural extension. The extra weight of the batteries is virtually meaningless (or even a plus for some duties) in a tractor. Most CUT owners have to lug their diesel fuel home from gas stations, and the plug-in reduction of fuel use would be a back saver in addition to making the air a little cleaner. Many of us don't use our tractors for long periods of time (and even when we do, the diesel should perform fine for us) so many of the smaller tasks could be performed without the diesel even coming into play. For most of us, the long charge times associated with 110 volt charging probably even wouldn't be that big a deal, though the higher voltages are good if you have the money or already have it.. Might even be possible on a tractor to have an extra battery that sits in the loader or in a ballast box when doing work not requiring the loader or rear PTO. The auxy battery could be left to charge while using the main one in the field. Lots of possibilities with a tractor that might not make sense with a car..
Probably one of the issues with a tractor would be temperature control of the battery, but it's likely in a tractor, the battery could be surrounded by plenty of insulation so even that might be easier than in a car. The CVT trannies, which claim to be more efficient, might be even more capable in an electric environment - likewise with the standard gear transmission, because it would seem to be a simple matter to build a forward/reverse pedal or lever for them both - just like on the hydros.. Lower cost of fuel, cleaner air, fewer trips to the filling station.. these would all be good things in the compact tractors imho. Anyone else out there think it would be cool?
   / Countdown to Plug in Hybrid CUT? #2
U get my vote. Hardly use mine for more than an hour or 2 at a time and I have almost free electricity so it would work for me.
Rick
   / Countdown to Plug in Hybrid CUT? #3
My wife won't know where I am on my property, unless there is a exhaust sound. ;)
   / Countdown to Plug in Hybrid CUT? #4
Electric fork lifts have been around for eons. Personally, I love the smell of diesel exhaust in the morning
   / Countdown to Plug in Hybrid CUT? #5
is that a bad thing????
   / Countdown to Plug in Hybrid CUT? #6
GE offered an all-electric garden tractor back in the 1970's. Put a lot of engineering into it and had what I thought was a very innovative product. I think they sold a couple of dozen (just kidding... but they never took off in the market). They're collector items now.
Biggest issue I see with a hybrid tractor is that there's very little coasting or braking done with a tractor, which is where hybrid cars recharge the battery during operation.
And if you go all-electric, everything a tractor does involves pulling under a load, so you'd draw down even a large battery array very quickly. Some guy in California cooked up an all-electric sports car which runs like stink for 10 minutes and then needs a 4 hour recharge. That would be similar to a tractor's operation, at least from an energy usage standpoint.
Personally, I'm holding out for a nuclear-steam turbine setup like the Navy uses. Cheers.
   / Countdown to Plug in Hybrid CUT? #7
Those are best for under water use.
I bet they could engineer a pretty good tractor tire fill battery if they put their minds to it.
   / Countdown to Plug in Hybrid CUT? #8
There is a teacher some where that tears tractors apart and rebuilds with electric. As the one post above says, electric fork lifts have been around along time and are quite capable of moving lots of material. Probably will not replace a field tractor that runs all day but, should work good for small acreages.
   / Countdown to Plug in Hybrid CUT? #9
Budddy of mine has an all elec tractor w an elec FEL. I think he just recently bought a snowblower for it too!
I'll have to get some pics one of these days.
   / Countdown to Plug in Hybrid CUT? #10
Has anyone actually looked at the cost of making electricity? Unless you are making your own you are paying way more than you are for diesel. The break-even point on solar cells might be as much as 5 - 6 years. Until then you haven't saved a penny. Remember, also, that energy is always lost in any conversion and transmission process. Diesel comes off the bottom of the distillery. It is the easiest and cheapest to make. It has more BTU per volume than gasoline or natural gas. Remember, also, that any DC politician spews out more noxious fumes than any diesel engine.
   / Countdown to Plug in Hybrid CUT? #11
Has anyone actually looked at the cost of making electricity? Unless you are making your own you are paying way more than you are for diesel. The break-even point on solar cells might be as much as 5 - 6 years. Until then you haven稚 saved a penny. Remember, also, that energy is always lost in any conversion and transmission process. Diesel comes off the bottom of the distillery. It is the easiest and cheapest to make. It has more BTU per volume than gasoline or natural gas. Remember, also, that any DC politician spews out more noxious fumes than any diesel engine.
I have all the electricity I need 24 hours a day 365 days a year for an initial cost of $3600 and for a yearly set of brushes, a set of bearings every 3 years and have had for 25 years from a water wheel. Even if you have no wind, water, or solar power available(unlikely you wouldnt have at least one of them partially) A diesel generator, a few batteries, and an inverter, you can make pretty cheap electricity. I guess cheap is relative,almost anything is cheaper than paying .26 a kilowatt hour.
   / Countdown to Plug in Hybrid CUT? #13
...and costs the most at the pump. What is that all about?
Not all crude is suitable for making diesel. An even smaller amount is suitable for making low sulfur diesel.
   / Countdown to Plug in Hybrid CUT? #14
An plug-in hybrid electric tractor is probably inevitable.
I love the smell of "clean coal" in the morning!
The airborn mercury does wonders for the corn.
   / Countdown to Plug in Hybrid CUT? #15
   / Countdown to Plug in Hybrid CUT? #16
I personally(after reading this article), would watch very carefully which scientist I rely on for information.
And as to mercury............buy a few more squiggly, curly-cue, light bulbs...........and dispose of them in lanfills:thumbsup::thumbsup::thumbsup:
   / Countdown to Plug in Hybrid CUT? #17
Electric engines and batteries are absolutely abysmal when the temps dunk below the big doughnut. Those of you who live in the northern states or Canada know exactly what I mean. I've driven electric forklifts for years in the plant, but that's in the plant! Also, those big, heavy, expensive batteries do wear out eventually, and I, for one, would rather not want to deal with that kind of cost and disposal.
You can have your hybrid, I'll keep my diesel!
Joe
   / Countdown to Plug in Hybrid CUT? #18
You are 45 miles from the nearest coal fired plant( CT only has 2)..............The chances of you smelling /seeing/tasting anything are lodged squarely at a minus 100!!!!!!! And there ain't no way it's affecting your corn............but if'n ya wanna get on a roll.............I'll tell you what to investigate.
Why do they not allow GMO foods across the big pond, and why has there been consecutive executive orders NOT allowing GMO crops to be evaluated by the FDA here in the good ole USA????
If you dig deep enough...........it will scare the crap out of you!!!!!
   / Countdown to Plug in Hybrid CUT? #19
I just read that Costco is removing their car charging outlets because nobody but Al Gore was using them. They were probably sick of him dimming their lights when he plugged in his SUV.. :laughing:
   / Countdown to Plug in Hybrid CUT? #20
Seems like we can't have a discussion anymore without political potshots.
:confused2:
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
154 (A52708)
154 (A52708)
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
