My Sweet Corn Reviews
/ My Sweet Corn Reviews #41
Did you plant the GottaHaveIt bi-color or white? I waited too long to order seed this year and the bi-color was sold out so I am trying the white.
Almost sounds like you just didn't get a good crop. Usually my plants were about 5' tall and both ears usable on the majority but the lower ear ripens later than the upper ear which I believe is normal for corn in general. With the cold wet spring we had I had to wait a few weeks past normal to plant so my corn is only about 6" high right now. :(
/ My Sweet Corn Reviews #42
It was bi-color charlz.
The second batch is tasseled out now and its about 6' tall it was planted 3 weeks later maybe 2? I have to look at my calender in the garden shed for sure but I am waiting on that to really get a better feel for this sweet corn it is a better representation probably.
The batch I am picking now was definitely too early it finally got to close to 6' by the time the ears all silked and I hope you are right I would like a bigger crop!
/ My Sweet Corn Reviews #43
Final thoughts on Gurneys GottaHaveIt now its all been harvested and processed. Is its absolutely the best sweet corn I ever ate its so sweet its hard to describe.
Everybody that I gave some to raved about it and it likes warm ground also btw dont get in a hurry planting it.
I got near 100% germination in the second and third planting it is very small seed and I had lots if not all doubles running it thru my earthway using the corn plate. Next year I will try a different plate see if I can spread them out a little.
As far as bugs go I found for me anyway just this season that liquid sevin in a pump up sprayer sprayed right on the silks just as they appear and them powdered sevin all over the whole plant a week or so later got me almost market quality corn. And by that I mean almost nil bug damage maybe 1 in 30 had a nibble on top but none had bugs inside the husk when I shucked them.
It worked great and was well worth the cost of the sevin for those that dont mind chemicals.
/ My Sweet Corn Reviews #44
Car Doc, Will you explain to me what you mean by double rows? Down here in east Texas I have never heard that expression as to corn planting. Thanks, speedy2
/ My Sweet Corn Reviews #45
Sure! It is my quirked way of doing things being lazy more than anything hahaha!
Please disregard the lack of cultivating in between the rows I am lazy but not that bad. We have had 30 some days straight over 100 mowing the garden isn't on my list plus its all done and will be turned into mulch this weekend with my bush hog anyway. :D
Its where I planted on either side of furrows I made with a middle buster and then seeded it on top of the ridges with an earthway seeder.
I flood irrigate the furrows with hoses and run a mini tiller between the rows down the furrow early season to cultivate it works pretty good I think anyway. Also the mini tiller has been in the shop for the last few weeks.
I made my furrows 6' apart so I can get in between and work/mow/etc another lazy thing I did. :)
/ My Sweet Corn Reviews #46
I plant the same way on flat ground as we flood irrigate. Two rows of seed per mound, approx 18" wide mounds. When I put the fertilizer in using the Earthway I just go right in between the two rows of seed. I use a cultivator to make the rows and then can make a few passes cultivating before the corn gets too high for my tractor to go over. Helps with the weeds in the early weeks but they sure take off later.
This year I rotated my corn into my raised bed area and plant 3 rows of seed per 4' wide bed. I put the fertilizer between the rows, so 2 passes of fertilizer per bed. The drip hoses then also run down between the rows.
I will have to look again but I think it is the pea plate I use with every other hole taped over. This results in misses so you have to watch it close and go slow. Better than lots of doubles with the price of this seed though! Then I use the bean plate to apply fertilizer... will have to double check I might have those backwards.
This 'shruken augmented' seed is kinda weird shaped and not graded so not all that easy to plant. I understand they use air planters versus plate planters when planting this type of seed commercially.
/ My Sweet Corn Reviews #47
Hey charlz what did you think about the corn you grew GottaHaveIt also didn't you the white variety?
Yup using the seeder to fertilize is sure a time saver and puts it right where you want it and just the right amount.
I have quite a bit of seed left over and I definitely plan on figuring out some way to plant it correctly before I put that much expensive seed down next year I was thinking the pea plate also might work?
/ My Sweet Corn Reviews #48
My corn is only about 3' high :D I don't normally get corn until about the 3rd week of August... might be a little later this year due the cool wet spring delaying planting... can't wait :licking:
/ My Sweet Corn Reviews #49
Ok well I hope it turns out good I am sure it will. :thumbsup:
We have had the exact opposite 1.80" rain since last year and a month straight over 100 yesterday was 113!
I had the corn on a timer to water twice a day for 99 minutes each time is the only way I got out of it what I did.
/ My Sweet Corn Reviews #50
I picked a dozen ears of my GottaHaveIt last week, and it was not as good as I have had other years because it wasn't mature enough. I remembered afterwards that the best and sweetest was picked when the ears looked like they would be tough. So now I have to wait a little longer. It seems like this variety never really gets tough or over ripe.
/ My Sweet Corn Reviews #51
Yup thats what I figured out also its very tasty and the sweetest corn we ever ate hands down! I would just wait on it until the silks are totally brown and about to fall off. I agree there is a lot wider window of opportunity than with other variety's I have tried this one is very forgiving time wise.
Then start pealing a few of the more mature ones down and do the thumbnail test it seemed to take mine up to a week and maybe even a little longer after the clear liquid stage to get a full kernel and still be milky.
The very best ones we harvested had a full rounded kernel but once they get their color they were still real good to eat but waiting awhile after that is the best I found.
We have had 35 days over 100 this summer and that couldn't have been good although I put 2"-3" of h2o every day on mine.
I am experimenting on a late season planting of GottaHaveIt after I had my garden all tilled my wife asked me if I could plant more corn since we didn't have much left over for us we gave so much away it was so good everybody raved about it! I put in 450' this year and next year will be more!
Well what the heck its worth a try I said with the summer we had so far. I put another 288' in Aug 2 and it was up 1 1/2" in 4 days and its got 3-4 leaves now and is 4-5" tall I am sure hoping it works that gives me until the first week of Nov w/o a freeze and I think I have a good chance to make it. :thumbsup:
btw anyone that says this corn doesn't germinate well isn't doing something right is what I say about that.
/ My Sweet Corn Reviews #52
Yeah I have found the same thing in years past, it is best to wait just a little longer than you would think. Even then I have found I can pick over a good 2 week period before it even starts to think about getting 'too far along'. After a while you get a feel for what the cobs should feel like in your hand before you pick them.
Still waiting to have corn this year, mine is just starting to silk :drool:
/ My Sweet Corn Reviews #53
hey charlz since yours is just starting to silk I will throw this out.
I dont know what you do for bugs but I found out just this year that liquid sevin sprayed right on the tops of the ears just as they silk and powdered sevin a week later and I may have done the dry once more later dont remember but that got rid of 95% of my worms.
My corn for once was just as clean and bug free as the store bought corn ymmv as always but it sure worked good for me this year! hth good luck on your crop :thumbsup:
One more thing I wasn't too wild about my crop was only 1 good ear per stalk until it was explained to me by a farm TV show so dont know what you have found but thats my experience so for with all the sweet corn I have planted at least this one is the most extreme example of it though of only 1 good ear I have occasionally gotten 2 on Kandy Korn.
I had a lot of doubles and really planted A LOT of corn because I used the corn plate instead of the pea plate which I did last week with every other hole taped over and this seed is so small its hard to regulate it anyway but that seemed to work good.
The farm TV seed dealers were talking about field corn which is supposed to make multiple ears or least thats what my experience from being on a farm was anyway they said the current planting strategy for best production was seeding close together and forcing the plants to make one good ear and this was giving the highest yields?! Cant argue with success so I am good with that its pretty easy to over plant this small seed anyway so go with it I suppose.
/ My Sweet Corn Reviews #54
Usually my first planting would be ready before the corn ear worms got bad. Later plantings would get hit hard. I tried BT for a few years and that seemed to help some. This year since my planting is late I was thinking of trying the mineral oil trick. We like to just cut the tip off the ears/cobs and soak them husk and all for BBQing so I am reluctant to use pesticide right on the ears.
I have had good luck getting two good ears per plant on about half or a little more of the plants. Things aren't looking too good this year. Don't know if it was just the poor weather, soil conditions or that I have the white versus bi-color or all three.
/ My Sweet Corn Reviews #55
What a difference a week makes! I picked several follow up batches of GottaHaveIt after letting it mature a little longer, and it was as sweet and flavorful as we remembered from previous years.
I've had very little worm damage this year and don't use anything to prevent it. I get maybe one worm per dozen and even that one will have little or no kernel damage.
/ My Sweet Corn Reviews #56
I tried that strategy for a while. You can get an occasional off year because of the weather, but I found ignoring the worms, along with any other problem in the garden, will in the end, generally lead to more of it in the future.
/ My Sweet Corn Reviews #57
It was brutal is all I can say in every extreme wet-cold to hot-dry we actually had good corn weather as gardeners in my area. We could control the h20 and the sun just came at us like a freight train day after day and still is and corn likes that as long as there is h20.
I cant comment on the white vs bi-color I wouldn't think thats it but the seed may have been bad I imagine that could happen or the temps?
My late season experimental planting is up to 12" at 3 weeks and 3 days and they have 5-6 leaves and stalks are 1/4 to 3/8" dia its growing 1-2" a day average looks like. I have high hopes but nature probably will slap us with an early winter after the summer we had be our luck.
/ My Sweet Corn Reviews #58
I figure I have another 2 weeks to wait. Since it was discussed here I did notice that probably 98% of the stalks only have one ear. Again don't know if it is due to conditions or the white versus bi-color. Next year I will plant both and see how they compare.
/ My Sweet Corn Reviews #59
I agree a week can make all the difference it is very forgiving it took me a bit to be able to leave some ears on I thought were close but it pays off.
Glad it worked not doing anything it never has failed for me to have bugs even when I used sevin this year a lot I still had a few get in. as always ymmv :thumbsup:
/ My Sweet Corn Reviews #60
I have a question about using the earthway with a plate for side dressing . i have the attachment for fertalizer but it is gravity fed so keeping a consistant speed is very important and if you get hung up on something it leaves a pile so i am very interested in the method and plate you use and do you go down both sides of the row? how far out ? Maybe i wont have to do a bunch of testing do you know how much it applys on a 100 ft row with the pea plate ??? Thanks for any help
