pharmvet
- Joined
- Sep 28, 2008
- Messages
- 535
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
In restoring a heavy duty disk harrow it has occured to me that a slugging or striking wrench might me useful to tighten and loosen the axle nuts. The nuts on my disk are square. I looked all over ebay at striking / slugging wrenches (after I finally found the proper name for them) and found many. I realize a machine shop could make one, but they can be had for around $40 so that would definitely be less trouble and possibly cheaper than having one made at a machine shop. The question is, what point wrench would you use for a square nut if a square wrench (boxed of course) could not be found? Also, do you hit these things with regular steel sledge type hammers, or do you use brass hammers?
