Square bale length
/ Square bale length #1
Lone Wolf
Member
Florida
Kobota
Using a new baler that I got at end of last year and was baling the other day. Bales seem heavy for me (needing to decrease weight so wife can pick up) so I know I will have to play with the density weight but on ave what is the length? Right now mine are @ 45". Seems alittle long but I could be wrong. Thanks
/ Square bale length #2
My bale length changes constantly, to accomodate my various customers who want specific lengths to fit wagons or barns. Average accepted practice is around 30-36 inches or packed dense enough that the bale maintains it's shape when picked up by the twines. You don't want a bale picked up (by hand) to assume the 'Oscar Mayer Wiener' look. It needs to be packed tight enough to maintain it's symetrical shape when lifted by the twines.
I tend to pack as tight as my Delmhorst meter will allow, that is, not climbing (within 20 minutes of bailing) over 7 points in moisture. Bailing and packing causes moisture rise, molding and a possible barn fire.
/ Square bale length #3
We do 30-40 inches, usually 36. Straw is usually 48" or so.
/ Square bale length #4
I try to make them 40" to 42".
Well....
I try to make them 4' X 4' and ROUND this year!
All the small squares are customers bales.....They buy 'em before I bale, and I'll make 'em whatever they request. After all, I'm not TOUCHING another "idiot cube" if I have anything to do with it!
/ Square bale length #5
I like to keep my bales at 35-36", it keeps them dense enough to stack well but are not too heavy so my customers are happy.
/ Square bale length #6
Well....
You mean you've matured.... Like me. I quit touching idiot cubes a long time ago. I'm not adverse to providing the crew so long as the customer pays for them but as far as me, the only idiot cubes I touch are the first one ot two to check the twine tension and the last one in the bale chamber, which I have to pull, out manually. I never leave any material in the bale chamber, even between jobs. The customer gets it all, I don't wangt it anyway unless, like you, it's round.
/ Square bale length #7
if I'm running wheat straw which incidentally usually turns into thouseands of bales, I try to set the length on the shorter side of longer. I get paid per bale so the more the merrier......:D
/ Square bale length #8
I did 4x4 rounds for a couple of years and I found it to be more work almost. The baler is so slow unless you have netwrap, you end up stopping and sitting tying. Then the bales are only 400 lbs or so, so you end up with a bazillion of them to move off the field.
I don't think I'd do rounds smaller than 5x4 or preferably 5x5. I hate the tying!
Well....
/ Square bale length #9
Most square balers have a chamber that is 14" tall x 18" wide (this is the most common size). Also, there are bigger balers that have a chamber 16" tall and 18" wide. There are also a few compact vintage balers that are 12" tall and 16" wide bale chambers but these are not very common.
General rule of thumb is to set your length roughly twice whatever the width is. Why: If you make your bales somewhere around 35 to 36" inches long it will allow you to interlock your hay stacks on the wagon, trailer, or hayloft such that 2 bales sideways at 18" wide (total = 36" length) equals the same 36" length that you have is set for length so you can interlock and stack the hay anyway that you like for optimized stack safety.
/ Square bale length #10
That is an interesting perspective and one I never looked at, however, we do 4-4's for horse people and the Amish because most horse people don't have the equipment to handle larger bales. A small CUT with a FEL will handle a 4-4 as will a small bobcat skid loader. The bigger ones, 4-5 and 4-6 need proportionately larger equipment putting them out of reach of the average equine customer and most equine operators want 'idiot cubes' becaue that's what they are set up to feed.
My wife's Percherons have always been fed rounds, the larger the better. I roll 4-6's in net for my own use, some rounds in the excess of 1500 pounds, but then again, that's beyond the capabilities of most people to handle. You need the equipment or you are S.O of Luck with large rounds.
I've tried (unsuccessfully I might add) to convince my largest contract customer to go to rounds. The raise Alpaka (sic) Lamas for the wool, which I understand is worth quite a bit. I even offered to make them custom round bale feeders (which I use to keep the rounds off the ground and limit waste through controlled feeding) but no dice. They want idiot cubes and I oblige. It sort of pains me to spit a thousand on the ground, knowing they have to pay a crew to load racks and fill their barn (I did, out of sympathy, loan them my Sno-Co bale elevator on a long term basis as I don't use it anymore).
Personally, I don't much care if it's net or twine (has to be net on clover over wheat straw) because cutting the twine is as easy as pulling a net wrap at least for me. I just run my box cutter dowm the side of the bale, grab the twine and pull it off. Takes about 15 seconds or just as long as pulling a net weap.
My bales feed at basically chest height in custom designed feeders with roof's and a large swing door to load the bale with the forks (eye to the sky). Pull the net or cut the twine, close the door and latch it, drop the feeder bars and let 'em eat.
My big gripe with rounds was how much forage was wasted. The ground contact plus the weather (rain and snow) caused an appreciable loss in forage and consequently wasted income. My feeders eliminated all the waste due to spoiled hay. I cut my consumption by a third.
Before, in the spring, I had a layered buildup of spoiled, rotten, moldy, peed on hay at every feed station. Now I have none.
Klene Pipe Structures in Indiana makes a feeder similar to what I made if you are interested.
/ Square bale length #11
... After all, I'm not TOUCHING another "idiot cube" if I have anything to do with it!
Believe it or not, My favorite part of haying is handling the idiot cubes. Many people pay exorabant fees to join a gym or fitness program. Never enjoyed lifting weights (even in my youth) much less now that I am middle aged.
Hate the thought of lifting weights or running just to be running, but I will throw hay bales all day as I enjoy that physical workout. Also, I will still play full court basketball for 2-3 hours with continous running and truly love every minute of it -again for an enjoyable physical workout. Now if you told me I had to run 3 miles from point A to point B then I would be miserable as I simply would not enjoy that type of workout just like I do not enjoy a workout like lifting weights in a gym.
This all said, I limit my acreage in order to keep haying enjoyable for me. If I was doing too many acres then I would not be able to physically handle it.
/ Square bale length #12
Hate the thought of lifting weights or running just to be running, but I will throw hay bales all day as I enjoy that physical workout. Also, I will still play full court basketball for 2-3 hours with continous running and truly love every minute of it again for the physical workout, but it you told me I had to run 3 miles from point A to point B then I would be miserable as I simply would not enjoy it just like I do not enjoy lifting weights in a gym.
Lets see, Dayton, Ohio.....
You are clse enough to come work on a weekend, and visit Cabelas as well.:D
I'll run some bales that will make you sweat and I'll provide a long sleeved shirt so your arms don't look like they had a trip over a barbed wire fence as well.....:laughing:
/ Square bale length #13
Actually have been to that Cabelas in Dundee several times. The company that I used to work for was home-office based in Plymouth, MI. Also regularly I still go to MI for SAE meetings pretty regularly.
I do prefer hay that is soft and subtle to the touch as compared to the itchey scratchy hay though. I never have to wear long sleeves on my hay as it is pretty soft. Also, I drop my bales on the ground and use a pick up truck and trailer so I do not have to ride the wagon behind a baler and breath all that dust. Wife actually does a pretty good job running the baler and tractor.
/ Square bale length #14
5030 for what you have if you wanted to really make life easy you should consider large square bales.
The old Case-IH 8575 that was built by hesston could bale the equivilent of 1200 small squares an hour!
The chamber is a variable so the hay can be made in different weight/thickness wafers for differnet uses.
For retail a skid to unload is all that is needed and they are easy to handle and store mechanically. You would need to move your big horse up a bit in horsepower as well.
/ Square bale length #15
No more new tractors. I'm retired and everything is paid for and the only time I get new equipment is when I have the cash and that's rarely now.
It feels better going in my pocket than to the finance company, much better.:thumbsup:
/ Square bale length #16
Have to love old age!
The wisdom of how to make dollars work! I have to stop, it makes me wonder how all these people get elected talking fiscal prudence when the government is soooo in the hole!
We have the best politicians that money can buy!
Thanks guy for the input. Hopefully the rain is gone and sun is out so I can play and make the baler adjustments after work today. Right now the bales can pop a hernia or other thinks, :laughing:
/ Square bale length #18
Same here when I was haying. 2x the width on the length so bale could be interlocked when stacking.
Rounds are still not all that popular around here. For those that do do rounds, bagging them in plastic bags is quite common to help with spoilage during our wet winters.
TANK MANIFOLD (A58214)
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A61165)
2002 Ford F-550...
CAT 930M (A58214)
CAT 930M (A58214)
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
