Decompression valve on Stihl - Got a question
   / Decompression valve on Stihl - Got a question #31
The 660 is a monster. Hold on tight. :)
   / Decompression valve on Stihl - Got a question #32
Fabs, look at the cutter teeth and see about the cutting edge, Cutting into earth or dirt is hard on a chain. You might be able to touch it up with a file, if not heavy damage. Or just take it to the shop and have them sharpen it on a cutter wheel.Never try to force a chain to cut, it should be pulling strips, not making sawdust..
Yep, I have already heard that, along with the suggestion that I wear chain mail underneath plate mail with full headgear when I use that thing.
After all the warnings I have received, rest assured that I will be holding on tight and wearing the appropriate safety gear when I use that saw. From the way most people describe it, you would think it should be banned from use because it has eaten so many people.
FYI - I am somewhat joking here, except for the fact that I will be very cautious while using it. Same way with any saw or gun. Doesn't matter if it is a .22 or .410 gauge or a .338 Win Mag or 10 gauge. Safety is always the key.
It is still cutting pretty decently in that chips are coming out of the back of the saw, but I can see some saw dust coming off the tip of the saw. It cuts about 1/2 as well as it did when it was new (i.e., it takes me twice as long to go through the same size log). So, I already swapped it out for a new chain and will sharpen that one once I get my electric chain sharpener for Xmas. I still have 2 other new chains for the saw sitting in the tackle box. Then, I have 3 chains for the 660. Hopefully, that will be enough chain for me to get enough wood to get me started on this "hobby" before I am deep into hunting season. Once waterfowl season gets here in November, I probably won't spend much time cutting wood.
Also bought my dad a couple of new chains. The chain on his Craftsman is pathetic. He tried finishing up a cut I made and all I was seeing was smoke and dust.
2009 FONTAINE TRAILER CO. 48 X 102 SPREAD AXLE FLATBED (A55745)
2009 FONTAINE...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2020 Chevrolet Tahoe SUV (A55973)
2020 Chevrolet...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
