Rotary Cutter Rotary Cutter Setup
/ Rotary Cutter Setup #1
deere5105
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
We will soon begin our biggest mowing project of the year in getting all of our food plots and roads cut before planting starts. I was able to use my new 3/4" drive socket set to take the blades off my MX6 mower to sharpen. This went much smoother than expected. Still had to use a 3'-4' cheater bar to get the nuts loose.
I have figured out about where I need to be running my top link to allow the mower to follow the ground contours. By running it a little long it seems to give more articulation. The lift height is obviously reduced but the trade off is worth it.
My question is, what is everyone doing with the sway chains while running the mower? I have run them both snug to keep the mower from shifting side to side and loose to allow it to have a little give if it encounters something unexpected. My set up works off of a turn buckle with jamb nuts to hold in place. I have not looked in my manual to see if it specifies. So what is the consensus?
/ Rotary Cutter Setup #2
I do exactly the same thing you do! I'm not sure if that's the "right" way however.
/ Rotary Cutter Setup #3
You have the mower set up correctly. It should articulate over mounds and depressions just fine with the top link a bit longer.
There should be a device on the mower 3PH top link attachment that will allow for movement as well. The Deere MX6 has a lever-type system that allows the A frame to move from what it looks like in photos.
For your 3/4" drive socket set you might want to consider a air-driven impact wrench. Get a good one (if you have a compressor) and use an adapter to step it up to 3/4" drive. It will find many other uses on farm equipment. Breaker bars get to be old news in a hurry - especially in tight places.
/ Rotary Cutter Setup #4
I set mine so there is a little play side to side; always have.
As stated earlier, I have run this cutter both with and without some lateral movement. Out of curiousity, I just pulled up the online manual and the following was stated:
Side Sway: Adjust sway chains or locks/blocks to minimize side movement at all hitch positions.
According to this it seems the cutter should be centered behind the tractor and locked down to prevent lateral movement. I guess my only concern was if it was rigid and contacted something it could make the impact worse.
gwdixon, I have a cheap 1/2" impact and recently got a more heavy duty 1/2". I have not yet got the new one set up. Not sure my current compressor will provide the volume of air necessary to loosen the rough stuff. I think it is a 25 gallon unit with the adjustable regulator. I can get the psi high enough, but don't know if it can keep up with sustained hammering on a tough job.
/ Rotary Cutter Setup #6
Sounds about like the way I do my MX6. I think some side play acts sorta like a shock absorber when you hit the unexpected, and you will. I try to set the top link to get the max float. If I want to increase the lift for transport on a road I just turn the top link to raise the back of the mower. I put the lower attatchment arms pins in the "float" position on my Kubota. It wiggles lots but so far so good.
How sharp did you get the blades? Here I cut so much stuff that I want to leave "frizzed" that I like the blades pretty dull. Did you get them flat out sharp? What does a one inch tree look like cut with a very sharp bushhog blade?
/ Rotary Cutter Setup #7
<snip>
<snip>
That's always been my thinking. Also, my dealer suggested allowing some side to side sway, so I pin the side links in the "float" position, too.
/ Rotary Cutter Setup #8
All of our tractors with pin adjustment hitches allow "some" side to side movement; minimize, but not eliminate. We only have one tractor with turnbuckles and I hate it.
On our old Fords the "stabilizer bars" were solid and we bent them pretty often.
/ Rotary Cutter Setup #9
I keep my turnbuckles tight on my lift arms and my top link very loose. I like to have lots of articulation on my mower, and rarely have a need to lift it. Even with it really loose, I can still lift it if I have to, but I can't remember the last time was when I needed to lift it.
Eddie
/ Rotary Cutter Setup #10
I have the turnbuckles. I allow for just enough play to get the arms on the implement. This allows for just a little side play, but never any danger of anything touching the tires.
Joe
I was able to see some of the factory angle still left on the blades. My mower is 2004 model and I am certain this is the first time they have been off to be sharpened. I was able to match the factory angle and grind them down until I had an approximately 3/8" to 1/2" flat edge. I did not sharpen them to a point. I have often thought this was preferred for the very reason you stated above. Although after giving it some thought I am not certain a rotary cutter could cut a point on a smal tree since there is no downward cutting motion??
/ Rotary Cutter Setup #12
Since the tree would be bent over I can see where a sharp blade would cut it level and sharp then the "stump" would snap back up and be a sharp stake. Not to hijack your thread but I wonder if even a sharp cutter actually will cut a small tree as I described above. Sharp blades would be a help I would think for grass/weeds. Would let you go faster with less horsepower.
For some reason I had not considered the object cut being bent over at angle. Good point. To my knowledge, mine has never been sharp enough to have that issue. Most of what I mow we ride fourwheelers on and I think I would have noticed if there were sharp objects pointing up. I did however notice a difference in engine loading when in thick high grass, as you mentioned above. We are about to mow probably 15 to 20 acres of mostly grass. That was my reason for wanting to sharpen them. Makes cutting easier, saves on fuel, time and gives better cut.
Put in about 15 hours mowing this weekend. Took a couple pictures of what one of the food plots I was cutting looked like. Most of the food plots had 3'-4' tall grass and also cut about 5 acres of 2'-3' tall bahia. I have read several posts lately about rotary sizing. I am running a JD 5303 with around 56 HP at PTO with a 6' JD MX6 mower. On several occasions I could tell the tractor was bogging and even had the clutch slip. I was running approximately 5 mph in these conditions. I am certain slowing down would have been a little easier mowing, but I was needing to get done.
/ Rotary Cutter Setup #15
I'm not certain but I think the sway chains are adjusted tight when the implement is raised. They will loosen a bit when you lower it down. The implement will not sway when raised but have a fee inches of play when near the ground.
/ Rotary Cutter Setup #16
Hey I notice you took off your rear chains. What difference in the quality of the cut could you tell?
I've noticed also that my MX6 makes my tractor grunt in heavy grass (44 PTO hp). I've lowered the rear wheel (which is raising the mower) one hole lower than you have yours and it is like I gave my tractor about 5 more horsepower. You can still get a great low cut by putting the front low with your hitch control. Try that set up and I think you'll be pleased with the results. Hight of cut will be determined by your three point hitch. It gives the mower more of a high back to low front angle to cut the grass and I'll never go back to that hole that it came set up in. I would sure like to see the Deere engineers explain the other holes that would let the mower ride lower. On mine the rear wheel would be hanging the air on the last three holes.
I actually didn't remove the chains, but never had them. I bought the cutter with my first tractor and they were not on it then. After reading the post about flail mowers vs. rotaries, I wish I had them. So far have not had anything bad happen with slinging debris. The cutter is left set up just how I received it. I may look into moving the rear wheel position to see how it does. I still have a bit more mowing to do. Thanks for the suggestion.
2012 TEXAS BRAGG COOL DOWN TRAILER (A65643)
2012 TEXAS BRAGG...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Asphalt Melter (A61572)
Asphalt Melter...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
